Question about HP Office Equipment & Supplies
Error Oxc19a0013 error Oxca0013
5 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: error message #Oxc19a0013----Ink system has
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
whitebirch
  • 433 Answers
SOURCE: cannot print any text
Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
Posted on May 13, 2009
  • 103 Answers
SOURCE: I have a system failed error code Oxc19a0013
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord
Posted on Jul 12, 2010
  • 5129 Answers
SOURCE: I am getting ink error
Is the phrase "Ink System Failure" in the message?
First check the cartridges. Remove all of the cartridges. Replace any that are low or empty. Check for damage or a blocked vent. Clear the blockage with a pin. If it is clogged with tape or the orange tab (that was in place during shipping), then remove the tape. Replace any that are damaged. Reinsert the cartridges and make sure that they are fully seated (clicked into place). Check if the error persists when you close the cartridge access door.
Try running the printhead cleaning utility from your computer. (HP Solutions Center under Setting, Print Settings, Printer Toolbox and follow the on-screen directions).
Remove the printhead and clean it. Then reinsert it and make sure it is fully seated. Remove the cartridges, lift the latch handle on the right and lift the print head straight up. This is done with cotton swabs or lint free clothes (coffee filters will work) and distilled or bottled water. During the cleaning do not touch the nozzles; also do not touch the contacts with your fingers. Wet the swab or cloth and wring out the excess water. Wipe the contacts on the printhead with the damp cloth first by wiping up towards the nozzles. Then with another damp cloth wipe the edge between the contacts and the nozzles (work in a right to left motion). Finally wipe down the ramps going away from the nozzles with another cloth. (Wipe each part until there is no ink left.) Dry each area with a fresh cloth.
Next take another damp cloth and wipe the contacts inside the printer. (work from top to bottom.) Dry the area.
Reinstall the printhead and lower the latch handle. Then reinsert the ink cartridges until they snap in. Close the cartridge access cover and check for the error message.
If the error persists, reset the printer. With the printer on, disconnect the power cord from the back of the printer. Disconnect the other end of the cord from the wall outlet. Wait at least 15 seconds and then plug in the cord (first to the wall outlet and then the printer). Turn on the unit.
If the error persists, then either the printhead needs to be replaced or the unit needs service. Unfortunately a new printhead is not returnable if you put it in and find the error persists.
For details and pictures: see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3737195#N65 .
I hope this helps.
Posted on Dec 12, 2010
I have an HP and it says ink system failure Oxc19a0013 what does that mean.
remove the catridges and then unhook the print head. wipe with soft cloth. otherwise you need to replace print head
Aug 01, 2016 | HP PHOTOSMART PLUS B209A All-In-One...
Hp photsmart 8250 system failed error code Oxc19a0013
According to the HP website, this error code means the ink system has failed, and the unit will need to be serviced by an authorized HP repair technician - An Ink System Failure or 0x Error Message Displays on the HP Printer...
However, you can try resetting the printer first -
Reset the product
  1. Without turning off the printer, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the printer, and then try printing again
  10. If the reset fails it will require a service.
  11. NOTE: if you are using refilled or remanufactured cartridges try the reset with genuine hp cartridges as they will be recognized as original authentic HP cartridges by the printer
Apr 13, 2015 | HP Office Equipment & Supplies
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Ink system failure Oxc19a0013 HP Photosmart B110
Check all of your cartridges to ensure that all of the protective tape has been removed. If you still receive the message after the check then power down your printer and remove the power cord from the back of the printer. Remove all of the ink cartridges from the printer. Wait 2 minutes, then plug the AC cord back into the printer. Turn the printer back on. Once the printer goes through it's power on self test it will ask you to insert the print cartridges. Go ahead and do so. If the error message does not display itself then you are okay to go ahead and use the printer. However, if you still receive the error display then you will have to have the printer serviced. Unless you have the tools, experience, and a copy of the service manual for your printer, it is best to have your local HP repair center take a look at the printer. The code signifies an ink system error, but there are a number of reason that can cause the error to display.
Mar 13, 2011 | Office Equipment & Supplies
I am getting ink error message Oxc19a0013
I hope this helps.
Dec 12, 2010 | HP Photosmart Premium C309A All-In-One...
Jul 10, 2010 | HP Photosmart 3310 Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Cannot print any text
May 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message #Oxc19a0013----Ink system has failed
Solution
Wait two minutes.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Seeker5211
Seeker5211
