Question about Paragon Heating & Cooling
Paragon 2000R pilot light up starts to light and goes out!!
Changed the batteries, pilot light lights up goes to fire up and then goes out!!!
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
cinderella_3
  • 4 Answers
SOURCE: Flame goes out Monessen Ventless fire place Model DLX24.
take a needle and put it into the end of the gas pilot hole. Wiggle it around in there, it just might have dust build up in there. Hope this helps ya.
Posted on Jan 17, 2009
muttandjeff
  • 359 Answers
SOURCE: When the pilot lights the furnace the fan comes on
could be a bad roll out switch a small thermal device located around the base of the burner ,locate on wirind diagram an ck with ohm meter should read closed , also could be to much gas presure if natural gas get the gas co. to check presure , also could be a faulty equipment ground from supply from breaker panel make sure well grounded and connections tight ,must have this gnd to keep gas valve open , hope some of these ideas help .
Posted on Dec 31, 2009
  • 3291 Answers
SOURCE: I can get pilot light lit, but I cannot get the
clean pilot might be small , or change thermocouple
Posted on Jun 14, 2010
  • 59 Answers
SOURCE: Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Posted on Oct 22, 2010
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
Tried to light our Paragon One gas fire - it hasn't worked and there is a continuous beeping noise
A continuous beeping sound means there is not enough power left in the batteries to light the fire. Change them, being careful to put then all in the right way.
Oct 17, 2010 | Heating & Cooling
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
The pilot light to our fireplace insert keeps going out. after the fireplace is lit, we here a click and then the pilot light goes out and the fire goes out. we already changed the thermocoupler.
Check venting, exhaust, the adj vent in fireplace. If that does not work your valve failed, warranty it. If no warranty expect to pay between 90 to 150 dollars.
Dec 05, 2008 | Heating & Cooling
Paragon 2000r gas fire - not coming on. pilot light is coming on with remote control but then goes out without activating or lighting the fire.
I have the same problem occasionally with a Paragon 2000R. It seems to be related to the thermocouple. The pilot flame does not heat the thermocouple enough. Usually re-arranging the the artificial coal to reflect some of the heat back to the thermocouple will just make the difference. Maybe it is time for a new thermocouple.
RB
Nov 08, 2008 | Heating & Cooling
Cozy wall heater lights fine then goes out after 3 or 4 minutes
Dec 19, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
46 people viewed this question
Top Paragon Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Paragon Heating and Cooling Expert? Answer questions, earn points and help others
