Question about Fellowes C220C Shredder
Fellowes c220c bin full sensors bad. Parts?
Sensors bad for bin full detection.
3 Suggested Answers
  • 99 Answers
SOURCE: I need a parts list for a Fellowes Model C-220
are you certain that the part needs to be replaced. I have seen several of these that could be fixed by bending them (if you hadn't tried it give it a shot) I'll take a look and see if I can find a parts list at work on Mon
Posted on Oct 30, 2011
  • 32 Answers
SOURCE: Have a Fellowes C220C shredder and the motor runs but blades do not rotate
So does it have a broken belt drive or gear stripped?
Posted on Dec 14, 2011
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
We have a Fellows Pwoershred 2200SC that keeps showing the full bin light even when it's empty. Tried cleaning the eye near the feed area with canned air as per recommendation by a shredder maintence...
There are also sensors under the shredder head to indicate when the bin is full. You either have a defective sensors or a dirty one (clean with air).
Aug 29, 2011 | Fellowes 2200SC Shredder
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
Model C-480C, always says bin is full! Where is the sensor?
Look up under the cutter asm and remove the paper shreds that are stuck in the blade assembly.Also clean the sensors with air or cotton swab.
Jun 03, 2009 | Fellowes Manufacturing C420 (Strip-Cut)...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Mar 26, 2009 | Fellowes Office Equipment & Supplies
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Fellowes C220C Shredder Logo
83 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
