Question about ViewSonic VX2235wm LCD Monitor
Where can i get one of these power supplys
Delta dac-19moo9
  • Fran Bednar
    Fran Bednar May 11, 2010
    There is an ebay seller that has a couple used pulls available.
    I bought two boards from them,, 1 woked ,1 didn't, So It's your risk.
    Yours could probably be repaired, If you post a picture I may have an idea as to what is wrong. Fran
    New Friend:
  • 12 Answers
A g@@gle search turned up a number of sources, however, you may need to only replace any stressed electrolytic capacitors on the power supply board. That's what I did to fix my same monitor - less than $5 in parts from ACME supply out of Orlando.
Posted on Apr 20, 2009
  • 1,684 Answers
You don't have to replace the unit. You can repair it yourself.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
Compatable IC required for DAP 8A
http://www.abnet.am/images/Viewsonic_va1912w.pdf
Jan 11, 2013 | Computers & Internet
What Dac board do i need for Acer P235H 23
The power supply board is the Acer P235H is not made by Delta Electronics so it is not a DAC board. The power supply board is this model is a ilpi-129 and looks like this:
I hope this helps.
Mar 27, 2012 | Acer Computers & Internet
The screen goes on for a second and then turns off. If I then turn the power on and off numerous times it eventually stays on. I put the screen off to 60 minutes. Every time the screen is allowed to turn...
Hello Geoff,
The problem you are having is caused by a power supply board that is failing. Your monitor uses the Delta DAC-12M033 power supply board. We have a repair guide for the Westinghouse LCM-20V5 monitor that uses the same power supply board posted o our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ Check out the web article, it should get you back going again. If you don't want to do the repair yourself we do offer a repair service. We can get deatils on this service here: http://www.ccl-la.com/blog/index.php/service-request-form/
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 26, 2010 | ViewSonic VG2021m LCD Monitor
Display is blank and the status light blinks Info:
The problem can be occurred due to low voltage the adapter may be defective please confirm that the adapter is ok.
Jan 29, 2010 | ViewSonic VG2021m LCD Monitor
No backlight. I'm looking for a schematic for the acer al1916w with power/inverter board dac-19m0005 rev: 01a bf.
<p>How about the whole <A href = "http://www.go-gddq.com/upload/2009_06/09060313346662.pdf">Service Manual</a> ?</p?
Jun 14, 2009 | Acer AL1916W 19" LCD Monitor
Hello viewsonic vx2235wm no power
this instructable might help http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
the dac 19m009 is supposed to simular to the dac 19m005, which is repaired in the instructable.
Apr 28, 2008 | ViewSonic VX2235wm LCD Monitor
Ground
ground is just a reference value.... connecting the -ve of batteries with ground pin of DAC is enough....
Feb 08, 2008 | Computers & Internet
DC power supply HP 6654A
This indicates a failure during Power-on Self test that there is a fault with the DACS or secondary VDAC/IDAC readback.
If a simple on/off cycle of your power supply doesn't resolve the problem, your supply will require servicing.
Nov 12, 2007 | Computers & Internet
ViewSonic VX2235wm LCD Monitor Logo
278 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
