Question about Samsung SGH-a737 Cellular Phone
Instructions on how to replace the slider part of the phone
Do you have instructions on how to take apart the slider part of the samsung a737? My daughter got a paper star caught in there and now her screen isn't working.
Thank you for your help
Rita
  • 3 more comments
  • Anonymous Dec 01, 2008
    How do I take apart the slider to replace the lcd screen on A737?
    Thanks in advance
  • Anonymous Jan 10, 2009
    i dropped my samsung A-737 in a pool, and i've been trying to figure how to take the top part that slides (with the screen on it) off the other part so i can dry it better.  anyone have any ideas??
  • doke2hobbs Mar 14, 2009
    My phone was dropped on the sidewalk, and the screen started to glitch every once and a while. Now, I am not even sure when it is on or off, because the entire screen is black! HELP!
    Thanks in advance..
  • Anonymous Mar 29, 2009
    I don't remember my phone dropping, but now, whenever I slide my phone upwards, the screen turns black. If I slide the screen downwards, its glitches.
  • frankig Apr 02, 2009
    i shut the phone off and when i went to turn it on the screen was black
    Problem Solver:
  • 6 Answers
1. take off the battery cover and take off the battery
2. take off the sticker hiding 2 screws that used to be behind the battery
3. unscrew every screw that you see on the back
4. take off the back
5. gently take off the chip. its safe unless your force it off
6. gently take off the slider part
7. unscrew the screws on the slider part
8. take off the 2 parts that are both beside each side of the LCD screen
9. now you can do anything you want
Posted on May 11, 2009
    Brigadier General:
  • 7,752 Answers
It is best to take the phone to a professional mobile service center and have them remove it for you.
Posted on Nov 02, 2008
My daughter has a Samsung SGH-A737 slider phone. The problem started out being intermittent but got worse over time. The speaker would go out and she couldn't hear anything when she was on a call. She...
I have samsung e250 with same problem.
sound plays with static, then disappears.
I try to shake the slider or press it hard, and sound comes back.
seems to be a bad connection to the speaker, or maybe a dry solder joint on one of the ICs.
Oct 21, 2010 | Samsung Car Charger for Fin, SGH-A117,...
Need manual for Samsung Slider Phone Model #S6H-A737
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 23, 2010 | Samsung SGH-a737 Cellular Phone
How to remove samsung a737 slider?
After spending several hours and a trip to Lowe's for the right screw driver n needed to take the phone apart. I still couldn't figure out how to remove the lcd screen. Therefore, I decided to buy the lcd screen online and I will take my phone to a professional for repair.
Aug 30, 2009 | Samsung SGH-a737 Cellular Phone
Samsung sgh-a737
You need to place the phone in a bag of rice for 24 hours. This usually works to get all the moisture out of the phone. I hope this trick helps.
Jun 23, 2009 | Samsung SGH-a737 Cellular Phone
How to remove the slider portion of a samsung model sgh-A737
I have a U600 phone, but maybe this is a similar construction. I was able to detach the slider by removing 6 tiny screws hidden behind the sticker which you can see when you take out the battery.
Jun 10, 2009 | Samsung SGH-a737 Cellular Phone
Samsung Sgh-a737 speaker not working
A very similar problem on a U600 was posted here. Maybe your ribbon cable is (partly) broken as well. When you slide the phone 'open', some copper tracks on the ribbon cable don't seem to make contact. When you close it again (or at least a bit), the tracks make contact again. After a while, the rip in the ribbon cable gets bigger and eventually, the tracks won't make contact anymore when your phone is closed again. I'm NOT a reseller of any kind, but I think you'll need a replacement for your cable. I had similar problems with my U600 and after the replacement it works just fine.
Jun 06, 2009 | Samsung SGH-a737 Cellular Phone
Trying to remove the slider on SGH-A737
To remove the slider mechanism, take out the 4 visible screws first (under the battery cover). Then on the back of the phone at the bottom, remove the 2 little rubber circles with a tiny flat head screwdriver to reveal 2 more screws, take those out. Take out the 2 screws on either side of the flex cable that is coming out just below the battery compartment. Next is the part that took me hours to figure out. L Beneath where the battery sits is a long oval shaped thing (=======) <- looks something like that (sorry I don't have pictures). This is actually a sticker. Peel this up and remove the 2 screws under it (keep the sticker intact becase you will need to replace it later). This will detach the slider from the phone. Make sure to gently disconnect the flex cable from the mainboard first.
From there you can see more screws that will help you take apart the sliding part of the phone to access the lcd screen if you need to replace it (which is what I was doing). It's pretty easy from there to get everything else apart. Make sure when you disconnect the cables from the back of the LCD screen, that you flip up the little release tabs on the connectors first.
Jun 05, 2009 | Samsung SGH-a737 Cellular Phone
I need to replace lcd display on the samsung sgh-a737 phone.
I had the same problem with my son's phone. Purchased an LCD from Y'ALL online. Lot's of aggravation/frustration but I was able to replace it with much technical help from two of my co-workers. You need a lot of patience but it can be done. Basically you have to dis-assemble the entire phone including removing the slider. I took some digital photos along the way, however they are a bit blurry. I can do something up in powerpoint or adobe for instructions. But be aware.... even with this it is not an easy fix.
Mar 26, 2009 | Samsung SGH-a737 Cellular Phone
Whats wrong with my phone
bad phone in general one in a 10000 chance u got it take back to retailer and do an exchange
Dec 06, 2008 | Samsung SGH-a737 Cellular Phone
How to replace the LCD screen on the SGH-A737 samsung
To remove the slider mechanism, take out the 4 visible screws first (under the battery cover). Then on the back of the phone at the bottom, remove the 2 little rubber circles with a tiny flat head screwdriver to reveal 2 more screws, take those out. Take out the 2 screws on either side of the flex cable that is coming out just below the battery compartment. Next is the part that took me hours to figure out. Beneath where the battery sits is a long oval shaped thing (=======) <- looks something like that (sorry I don't have pictures). This is actually a sticker. Peel this up and remove the 2 screws under it (keep the sticker intact becase you will need to replace it later). This will detach the slider from the phone. Make sure to gently disconnect the flex cable from the mainboard first.
Oct 24, 2008 | Samsung SGH-a737 Cellular Phone
Samsung SGH-a737 Cellular Phone Logo
501 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
