Question about Bissell Vacuums
My Bissell Spot Bot won't suck up water anymore and the hose is not clogged
5 Suggested Answers
SOURCE: clogged spot bot
There is a very small, white water filter (approx. 3/8" in diameter/ 1/8" thick) inside the "seat" where the solution tank connects to the machine itself. Could very well be your problem if you are in a city environment, or any other situation where hard water is present. This is a very easy fix; discovered it when my wife experienced the exact same problem.
1) Make sure other causes have been eliminated, such as clogged nozzles, etc. (Refer to owners manual.)
2) Ensure that the solution tank is indeed seating properly with the machine, (a few small bubbles rise from the connection once made.)
3) Remove solution tank. With needle nose pliers or a very small screwdriver, GENTLY remove the white filter from the black, movable "seat" connection on the machine.
4) Run the machine on manual (without the filter) to determine if this is indeed your problem. (Don't run for an extended period of time this way if this actually is your problem. The filter is there for a reason!)
5) Simply wash the filter gently between thumb and fore-finger. Vinegar may be used, but simple tap water works as well. If clogged, you should feel grainy, hard water type scale/ lyme build-up when cleaning the filter.
6) Recycle the original filter or replace if necessary. (It would be very easy to make a new one without going through the hassle of dealing with OEM parts or Bissell. Just go to your local hardware store and they should be able to help you out with no problem.)
Voila! Spotbot works again.
Hope this helps!
Posted on Feb 11, 2010
SOURCE: how can i clean the hose of my bissell spot bot?
Well... it's sub optimal but this is what I did, run hot water into the sink, add a few table spoons of bleach and run the hose along the edge of the water to slowly **** it into the hose (the tank fills very rapidly and the auto shut off will activate). You will want to run 4 or 5 tanks of waste to get the bulk of the gunk along the walls out and this will also get rid of the serratia growing (red stuff). If you dangle the hose in a u down the front of the sink and shut off the machine you can catch about a pint of water and bleach solution in the hose and roll it around inside the hose then let it sit for awhile and finish by sucking it into the waste tank, not perfect but my hose is much cleaner.
Posted on Jun 28, 2009
SOURCE: Need to clean hose.
I filled a bowl with hot bleach water and sucked the water up. It cleaned the hose pretty well (along with the gunk that was stuck in the hand wand). Mine was filthy. It looked like it had mold growing in it. Then I ran several rounds of hot water through the hose. I alternated hot water & bleach. Did this about 8 times. It is not perfect, but it sure does look a lot better. 90% of the gunk is gone.
Posted on Sep 03, 2009
  • 52 Answers
SOURCE: Need a Bissell Spot Bot Manual
You'll find manuals for several Spot Bots at the link below. There should be any significant differences among the models.
http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
Posted on May 19, 2010
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
May 18, 2010 | Bissell SpotBot Hands-Free Compact Deep...
Bissel spot bot water not coming out of tank is not a year old and tried manual wand and the water doesn't come out there either. any advice. Is not a year old yet.
you could take the end of the handle off 2 screws i think check the line for a clog or just take it to a bissell service center it will be covered under warranty
Dec 16, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
The cleaning solution on my bissell spot bot is not being pumped through....on the stationary mode or the manuel hand held mode with the brush attachment
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Nov 07, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
Need to clean hose.
Aug 05, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
How can i clean the hose of my bissell spot bot? It looks like mold is beginning to grow in the hose.
Jun 15, 2009 | Bissell SpotBot Hands-Free Compact Deep...
Vacuums Logo
2,339 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
