Question about Epson GT-S50 WorkForce Pro
Epson gt s50 scanner
Clean inside of glass
  • 19 Answers
SOURCE: Scanned pictures has thin blue line running through it
I had the same problem with My Espon Perfection V500. I called tech support and they had me do the following sequence.
1. Turn off the unit
2. Unplug the lid from the base
3. Replug in the lid.
4. Turn the unit back on
5. Go into the Epson software in Professional mode, Configuration, Other and select Reset All
6. Rescan the picture.
It worked after that. Of course it also lost all my preset sizes in my Custom box and any other settings I had. I suspect the lid plug is what the problem was.
Another word to the wise. To test it I put in a picture that was laying on my desk and rescanned it and was disappointed to see the line in the result. A few minutes later I discovered that this particular line was in the original picture.
Posted on Apr 18, 2009
FixinFax
  • 3085 Answers
SOURCE: The inside of the glass needs to be cleaned. How
USUALLY you have to flip them upside and remove 4 screws to split the scanner in half, sometime the screws are hidden under rubber feet on the bottom.
Some just snap together.
Posted on Sep 30, 2009
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
  • 181 Answers
SOURCE: How do I clean the underside of the glass on the
Scanners are not meant to be user serviceable. This means that to clean the inside of the scanner, its better that it be brought to the manufacturer who can do this in a safe and correct manner. Believe me, it is worth doing this than ending up having a non-working scanner.
Posted on Jan 11, 2010
SOURCE: scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Posted on Feb 14, 2011
Scanned images have lines through them
If the lines are vertical, the glass may need cleaned, or the unit itself may need a good cleaning. Horizontal lines usually mean the machine itself needs a good cleaning as the scanning apparatus is not moving smoothly.
Apr 07, 2014 | Epson GT-1500 Flatbed Scanner
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
How do I get rid of the line running down the scanned document?
Simple, clean the ADF glass that the paper passes over during a scan (not the flatbed glass itself, just the thin strip of glass at the head of the flatbed glass). A speck of dirt on the glass will appear as a line down the length of the paper.
May 23, 2011 | Epson GT-2500 Flatbed Scanner
How do I clean the underside of the glass on the 2450 epson perfection scanner?
Jan 11, 2010 | Epson Perfection 2450 Photo Flatbed...
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
Sep 29, 2009 | Epson Perfection 3170 Flatbed Scanner
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Scanner glass clean
Jun 21, 2009 | Epson Perfection V100 Flatbed Scanner
How to cleas Epson Perfection 3200?
use a lint free cloth, slight moisten the cloth and clean the glass.
do not spray anything on the glass.
Apr 04, 2009 | Epson Perfection 3200 Photo Flatbed...
Cleaning
Unfortunately, cleaning dirt or debris from under the glass requires disassembly of the scanner and must be done by an Authorized Epson Servicer. Please refer to the Epson Customer Care Centers. if its still within the warranty period call epson.
Jan 18, 2008 | Epson Perfection 4870 PHOTO Scanner
Epson GT-S50 WorkForce Pro Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
