Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore Coldspot Model# 72864100 - Top Freezer / Water leaking from valve below the freezer into the inside of refrigerator
Why is water draining into the inside of refrigerator from an opening under the freezer box
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 150 Answers
SOURCE: Refrigerator Water Leak from opening under Freezer
easy fix my man. couple of possibilities: 1) the fresh food gets cold air from the freezer via the vents where the water has been coming out. the water has frozen up in the vents and is blocking the airflow. the reason the water was coming out in the first place is a slow drain. open up the evaporator cover inside the freezer. get all the ice out of there and clear the drain. a little bleach will kill the gunk that made the drain flow slowly.
2) you have a defrost issue and the coil is loaded up with frost causing no airflow to the fresh food section. check the defrost heater limit and timer. none of these repairs should be over 150. but thats in lawton ok. if you live in L.A. or NYC get the wty.
Posted on May 07, 2008
mgprice
  • 744 Answers
SOURCE: Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 14, 2009
Testimonial: "Greatly appreciate yor help, Mike. Found screws to remove back panel, but the ice maker is plugged into a hole in panel can this be unplugged?"
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jan 26, 2010
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Top freezer leaks water into lower fridge on our sears kenmore #70267990
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 26, 2009 | Kenmore Refrigerators
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Kenmore coldspot - How do you remove the ice maker box to clean
I have the exact same Kenmore and exact same model #77292798. It's the top freezer model with ice maker. Here's what I did:
Empty everything in the freezer.
Turn water to ice maker off from source behind unit.
Remove bottom panel (two screws)
Every screw in the freezer is the exact same size. I used a screwdriver style socket and, I think
this works the best.
Remove ice maker (4 screws) and unplug from socket.
Remove rear panel (2 screws).
My freezer was loaded with ice underneath the bottom panel. The ice scraped away easily. There is a tin pan underneath the coils that drains toward the middle where the drain hole is. Again, my freezer was full of ice beneath this tin pan and, I had to scrape away. You may be tempted to try and remove the coil because it would be easier to get to drain hole. I tried this and, it did no good. Don't try it. Once all the ice was scraped away, I realized that the drain hole was plugged with ice. I used boiling hot water and used a squeeze bottle to pour the hot water into the drain hole. I then wrapped a paper towel around a thin screwdriver and used that to soak up the now cold water in the drain hole. After doing this a dozen times or so, the drain finally cleared.
Then, reassemble. This was a much easier task than I thought it would be and, will take care of it much quicker next time.
Mar 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
