Question about Lands Phones
Need Philips CD245 powersupply cable for handset
Need to purchase the Philips CD245 power cable for handset (not base unit) - cannot find a seller, because existing cable damaged by heavy piece of furniture damaged cable.
richa33
  • 71 Answers
SOURCE: Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Posted on Jan 21, 2009
SOURCE: Philips cordless phone CD245 Handsets
Simil problem. Also then clocking in DSP not oscilation. then facking mather of Philips
Posted on Jul 22, 2009
SOURCE: Can't find user manual and
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=CD2454S/05&slg=en&scy=GB
USER MANUAL On Philips website
Posted on Oct 09, 2009
oussreal
  • 5 Answers
SOURCE: Can't reset Philips Zenia 300 base station
you can change his batterie !!! googlesearchiconshadow.gifsupersearchiconshadow.gif
Posted on Feb 14, 2010
SOURCE: Philips CD245 phone not working.
the same problem after it worked 3 years. any solution arround?
Posted on May 23, 2010
PHILIPS CORDLESS CD245 TRIO AND other 2 handsets power requirements (Adapters lost)
It should say on the bottom of the base unit. I would expect 5-6 volt 500ma. That would be the size that would charge those batteries.
Oct 16, 2016 | Philips Lands Phones
Can I use Philips CD240 CD245 handset on a philips dc445 base
Simple answer yes they are compatable I just did it as I could not find any CD445 handsets.The manuals are downloadable from Phillips just search for CD445 or CD245 manual.Just press speaker button on 445 base for 5 seconds untill it beeps twice,then on new 245 handset menu/ register enter default code 0000 and bingo its live. Oddly the newer handset bases are 9v and not compatable with 445 bases which are 6v and have different contacts so you cant sit your 245 in the old base.My new 245 came with a new base anyway so no problem.
Apr 06, 2012 | Philips Lands Phones
HI! I have a Philips CD245. It seams to be that the base unit is dead or about to die!!...I conect the power and the light goes on very weak for abou 1 or 2 seconds. What component is not working fine? I...
Hi marybls ,
I am afraid this is a sign that the internal board of the main base unit is either corrupted or rusted. i would highly suggest for you to take it to an electronic shop to get it repaired as no further solutions can be given on line.
i hope this helps.
Mar 28, 2011 | Philips CD2451S 1Line Cordless Phone
I have a phillips CD240 cordless phone, on the screen is flashing SEARCHING and wont make or receive calls.
Hi, I solved this issue this morning. "Searching" means the handset cannot find the signal from its base, and if you check your base, it's more likely than not, dead. In my case, I checked this by pressing any button on the base, i.e. answer phone etc., there was no response (although the handset seems to recharge power fine for some reason).
Therefore, I went and bought a new cheap GAP compatible (binatone 1800 Single at Comet - 14.99). I then set up the base, put it in the registration mode as per the binatone instruction. Then on the Phillips CD245 handset and gone through the above registration procedure... and Voila! It worked.
Now I have a brand new base that came with 1 new handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good (no different from the previous genuine set) and they retained all the telephone numbers registered with the handset.
I don't have any high regards to binatone specifically as a brand because our last corded phone system was rubbish and died shortly after 12 months guarantee but to me it looks as if GAP compatible cordless phones have certain life-span however cheap or expensive they are (while handset seem to last much longer). Threrefore, there is more incentive to buy a cheap base new (of any make that are GAP Compatible) then connect your old handset to this base and live on 12 months manufacturer's guarantee and hopefully more. On the web, I saw some comments that are saying GAP Compatible phones and base sometimes do not successfully register each other (despite even being of the same make or brand). Obviously the users make such attempt at her/his own risk but I can confirm that the above combination worked for me.
Just for info, to do the registration successfully, the both base and handset must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting".
I hope this is helpful.
Best,
Ken
The above, however, works only if the Base is still functioning.
Jan 02, 2010 | Philips DECT5112 Cordless Phone
Phone Philips CD245. Due to power cut the phone unregistered from base. Need to reset phone because don't remember PIN. Reset function does not work because there is no message 'Confirm?' or WELCOME. Can...
hi rsacauto
below is the manual for the unit to walk you through resetting it
http://ph.diplodocs.com/jim/PHILIPS/CD%20245-_E
hope this helps,
regards.
voodoo
Jul 05, 2009 | Lands Phones
Philips cd245 duo wont register and wont reset
Hi, I sort of solved this issue. What you cannot confuse here is that when you are doing "Registering" on your existing handset, the base has to be in the registration mode too. To get the base in the registration mode, you have to press <page> (or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode". You can then go through the procedure you describe and the handset will beep with Registration number on the screen. This is however a fix only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode. Then on the Phillips CD245 handset and gone through the above registration procedure... and Voila! It worked. Now I have a new base that came with 1 handset, then 3 of my CD245 handset are all registered with it. So far, the sound quality is good and I also managed to have kept all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Apr 04, 2009 | Lands Phones
Can I use handsets from another DCT 748 unit to expand my DCT 748
Short answer:
No. This model of phone can only support 4 handsets. If you need more than that, you will need to have a second base unit.
Detailed answer:
One of my handsets went bad, and I just bought complete DCT748-4 package from a seller on eBay for a very good price. This set was used, but in very good condition. I didn't need the whole set - just one handset - but like I said, it was a good price. Anyway, I began by telling my old base unit to de-register handset #2 (the failed unit). However, I then found that I could not register the "new" handset with my old base unit because it was already registered to the "new" base unit. So, I first had to apply power to the "new" base unit and de-register the handsets. Then, I placed one of the "new" handsets onto my old base unit, and it said "Handset Registering ..." and registered just fine. Just for the fun of it, I placed one of the other spare handsets into my old base unit. It said "Hanset Registering ..." but then it beeped and said "Registration Failed." This is because I already had 4 handsets registered to my base, and the base can not handle a fifth handset.
Feb 15, 2009 | Uniden DCT-748-4 Telephone
Dec 22, 2008 | Philips DECT 2252S Cordless Phone
Philips cordless phone CD245 Handsets will not find base station - they keep searching all the time.
Jun 22, 2008 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
