Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchenaid double-drawer dishwasher will not start
Dishwasher was recently installed brand new by plumber. Seems to have power, humms a little, but then does not go thru cycle.
I just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Posted on Nov 15, 2008
Check drain area. I cleaned up the scaling on my heat sensors with a small brass brush and hot water. Then it had no problems.
Posted on Oct 24, 2008
My double drawer kitchen aid dishwasher is stuck on rinse mode
I tried this once an it worked. Tech came from Sears an asked where fuse box was. He tripped the breaker for dishwasher. Flipped it back on after 10 seconds. Came to the dishwasher an it was like new again. He said sometimes they need a reset. If that did not work he had to replace the panel. Hope it works for you.
Jan 28, 2015 | KitchenAid Kitchen Aid Architect II 24 In....
Replace check valve kitchenaid dual drawer dishwasher
look under the sink for the valve its huge an inline with the waste tube
if not then its here
https://www.youtube.com/watch?v=rOio5HaWeFU
Aug 17, 2014 | KitchenAid KUDD03DTSS DUAL DRAWER...
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Have a kitchenaid double drawer dishwasher. While running the bottom drawer the top drawer fills up with water. Had the filler valve on the garbage disposal changed. Issue still continues. Any suggestions
Mine does the same thing! (Same model) I've finally discovered that if I start the bottom drawer first and the top drawer just after that doesn't happen as much. Also, if I run the garbage disposal (and water obviously) while it's starting (I will try to do my hand washing while the dishwasher is getting going) that seems to keep this from happening as well. I've given up running just one drawer, which totally defeats the purpose of buying the 2 drawer dishwasher. But it does keep me from having to bail the bottom drawer :-( I'd like a better solution to this too!
Sep 10, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kitchenaid dishwasher wont stay closed
you might need a new Latch, Drawer (left Hand) part number 8194053 okay
Feb 07, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Dishwasher stopped working. Suspect electronics issue.
An expert from another site says it's a faulty control panel and may need new actuators.
Jan 31, 2009 | Dishwashers
Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
891 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
