Question about Blaupunkt America SR04 SIRIUS Radio Receiver
Help My receiver was working fine, then I left my car and went back and turned it on, and the display was flashing but the unit would not turn on. I checked the power and everything was fine, the unit was in the cradle correctly also. Please advise.
0 characters
1 Points
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Acquiring Signal
Try resetting it to defaults if you haven't done that yet. I had a similar problem with a Stratus 4, and that took care of it for me.. Sounds like perhaps some kind of NVRAM gets corrupted and a full reset clears it up.
Good Luck. Hope it helps you like it did me.. Just remember to jot down all your presets first, because you will need to reset them.
Jun 03, 2009 | Sirius Satellite Radio Receiver
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
White screen
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking it with one hand until the battery came out into my other hand. After about 4 or 5 gentle shakes, it came out. (3) Wait about 10 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Jan 19, 2009 | Pioneer inno2 Portable XM Satellite Radio...
My delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Satellite radio turns on and ond off
I took the reciever out of the cradle and slammed it on the dash a few times and it works fine now.
Jan 15, 2008 | Kenwood Here2Everywhere SIRIUS Radio...
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Aug 11, 2007 | Clarion (NAVSIR) SIRIUS Radio Receiver
It occured to me after plugging it into the car adapter and turning on the car ignition. I ended up sending the unit to Panasonic and they sent me another. This must be a known issue.
Aug 10, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Blaupunkt America SR04 SIRIUS Radio Receiver Logo
23 people viewed this question
Top Blaupunkt Home Satellite Radios Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Home Satellite Radio Expert? Answer questions, earn points and help others
