Question about Kenmore Dishwashers
Kenmore dishwasher model # 363.1442591 wont drian
Model # 363.1442591 wont drain
SOURCE: dishwasher seems to be clogged, wont drain
I had the same problem and it was solve by checking the food disposal were the dish washer is usually attached for draining, if you resently replaced the disposal it could be that the drain hold was never openned. I hope this helps
Posted on Apr 22, 2009
  • 57 Answers
SOURCE: kenmore dishwasher 206c1513p007 wont drain
take the cover off the bottom of the dishwasher inside and remover the built up food and turn the wire by hand and even use your hand as a plunger
Posted on Jun 29, 2009
garing
  • 998 Answers
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Posted on Aug 11, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
  • 677 Answers
SOURCE: My Kenmore dishwasher model 363-1404596 does not
is there a white film/residue on them? if so it is hard water and not your dishwahser. go to www.dishwasherfilter.com and check out there new product for this problem. it works amazing.
Posted on Nov 09, 2009
Kenmore Ultra dishwasher model 665 wont drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 11, 2011 | Kenmore 24 in. 16032 Built-in Dishwasher
My Kenmore elite 40512900 stays at 7 minutes
well often when it hits the last ten min of a cycle it is trying to drian more times then not it isnt or it hasnt senced it has drianed so odds are that your drian pump not drianing or you have a bad pressure switch. i would start with the drain pump often it has a filter that get clogged and can be gottin to from the front
Jun 02, 2010 | Kenmore Elite 45986 Front Load Washer
Wont drian water
drain pump will need to be replaced. it depends on make and model but sears parts direct.com you can order parts and for repair call up10 techs and ask for the price toinstallpump go with the one that is the cheaopest but the sounds like he knows what he/she is doing. if this helps please post me a 4 thumbs up post thanks
Mar 01, 2010 | Dishwashers
I have water that hasn't drained out of the bottom of dishwasher and when trying to run it, the panel lights come on, but the machine does not turn on.
It sounds to me as though the water drain line is connected to the house too low. If it is installed using the sink drain line be sure it tees into the drian as high up as possible. As far as the machine not turning on, it could be the water level interlock that sences water in the machine and will not allow it to start.
Hope that helps. Good luck
Dec 17, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore dishwasher 206c1513p007 wont drain
Jun 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Water not completely drianed after running, is this normal?
Hello. There should be no water left in the bottom at the end of the wash cycle. There are a few possible causes, the most common one being debris in the small pump that pumps the water out of the machine and into your sink drain, or debris in the hose vrom the dish washer to the sink, or a blockage where the dishwasher empties into your food disposal [if you have one installed].
May 31, 2009 | Kenmore 15762 Dishwasher
My dishwasher wont drain out? any ideas?
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Kenmore Dishwashers
My dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
