Question about Dymo LabelWriter 330 Thermal Printer
Can I import .lwt files to Dymo sw with V8 driver (for Windows 7)
I got a new computer Windows 7. I finally got around to upgrading my dymo support with the V8 drivers. It can't open all my .lwt files. Hope I don't have to reenter them all again as .label files? Should I have upgraded to a lesser driver version, if there is one?
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Posted on Apr 29, 2009
SOURCE: dymo label point 200
Dymo website, Support Tab:
http://global.dymo.com/enUS/TechSupport/default.html
Drop down box and select your product.
Print out you instruction manual.
Posted on May 11, 2009
MCSE_Fixit
  • 23 Answers
SOURCE: how do you print vertical labels?
Here is the link to your users manual, which will help explain other functions you may find useful.
http://global.dymo.com/enGB/Manuals/LetraTAG_QX50.html
Hope this helps...
Gods Bless.......
Posted on Jun 22, 2009
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
How do i transport the address book from old computer windows xp to new computer vista
The easiest way would be to identify the location and the file your Dymo printer uses to store its address. Copy the File to a USB memory stick, copy the File on the USB stick to your your new computer, and when you start up your Dymo printing utility open the copied file as your default address library.
The problem you may run into can be caused by different versions of the Dymo printing utility. You may be forced (using the Dymo printing utility) to export the address book on the XP computer and then import the address book on the Vista computer. The picture below outlines this procedure using Dymo printing utility v.8
Also, if you have created any custom label designs you will want to transfer them as well
Jan 17, 2014 | Dymo LabelWriter 310 Printer
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
Dymo labelwriter turbo model 90479 driver
You can download the Windows 7 Driver here:
http://www.dymo-label-printers.co.uk/dymo-labelwriter-drivers-windows-7.html
Note: you don't say if it is a 300/400/450 series, but if it's a 300 series and the model is NOT listed in the compatible printers on that page then there is NO SOLUTION - your printer simply will not work with Windows 7 as Microsoft dropped support for the old USB chipset in this OS...
ps. there is a server problem at the moment so if you can't download 8.4 try 8.3 it will still work just fine.
Apr 11, 2012 | Dymo LabelWriter Office Equipment &...
Do I need the software to install Dymo LabelWriter 400 Thermal Printer to my computer?
Hi, most printers do need a software/driver in order to be recognized by your computer. If in case you don't have the driver yet, you may download it from this site:
http://www.labelvalue.com/dymo-software.php
Select the software/driver compatible to your computer's operating system (ex. windows 7, windows xp, Vista, etc.) Please save it first to your computer before running it.
I hope this helps.
Aug 10, 2011 | Dymo LabelWriter 400 Thermal Printer
We just changed to Windows 7 and the Dymo Label Writer 400 will not work - is there a download or some kind of fix to hook it into Windows 7 Thank you. Lori
Visti this link:
http://sites.dymo.com/Search/Pages/SupportSearchResults.aspx?k=Labelwriter 400
You probably need an update driver for your Labelwriter. You will need to determine if you are using Windows 7 64 bit or 32 bit. You can contact Dymo to ask for further information.
May 17, 2011 | Dymo LabelWriter 400 Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Trying to reinstall dymo software onto a new computer
Does your new computer use WINDOWS VISTA? Go to: www.dymo.com, left click on SUPPORT, select your product from the list, and select DRIVERS AND DOWNLOADS. They should have a VISTA compatible driver you can download for free.
Aug 12, 2008 | Dymo Office Equipment & Supplies
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 330 Thermal Printer Logo
514 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
