Question about ClickFree Backup HD225 250GB USB 20 Automatic Backup Portable Hard Drive
From XP to Windows7 with Clickfree Portable Backup HD225
I have a new HP 3 in 1 computer with Windows 7. My clickfree backup was used on my XP. Can I use the Clickfree backup on my new computer?
3 Suggested Answers
  • 3278 Answers
SOURCE: My computer (Dell Inspiron 1525)
Hello.
From Click Free Support:
Ensure that the Clickfree device is plugged directly into your computer.
Once connected, wait 3 minutes to confirm the application did not start as expected.
If the application did not start, open your "My Computer"(XP) or "Computer" (Vista / Windows 7.) and check to see if you have both Clickfree_System and Clickfree_Storage.
Double-click on the Clickfree_System drive or browse the Clickfree_System contents and double click StartMyClickfreeBackup.exe.
If the Clickfree™ application starts and begins a backup, then Autorun may be disabled on the computer.
To reenable AutoRun:
FOR XP USERS:
To re-enable Autorun you have to go and download the official Microsoft Windows XP Autorun Repair Wizard. http://www.microsoft.com/downloads/details.aspx?FamilyID=c680a7b6-e8fa-45c4-a171-1b389cfacdad&displaylang=en Please follow the steps outlined by Microsoft on how to use this repair tool.
FOR VISTA USERS:
To re-enable Autorun, go to Control Panel and select Autoplay. Choose the Restore Defaults button in the Autoplay window which is located at the lower left hand corner.
FOR Windows 7 USERS:
To re-enable Autorun, go to Control Panel and select Autoplay (If you do not have the Autoplay option, In the upper right Click on "Category" and select "large icons". You will then be able to select autoplay.) Choose the Restore Defaults button in the Autoplay window which is located at the lower left hand corner.
It's also possible that the ClickFree USB cable is defective. Replace if necessary.
Hope this helps.
Posted on Jun 15, 2011
alpug
  • 1961 Answers
SOURCE: My old computer (XP) crashed.
Hello!
Please check if the ac adapter is still working. If you have a digital multitester, check if there is an output voltage from the ac adapter when it is plug in the ac outlet. Set the range of your multitester to DC. If the ac adapter is working you should see the LED indicator lamp lit in your Clickfree when it is plug in the ac outlet.
Please check if the usb cable is not faulty. Try to use other usb cable.
Please check the usb port on your new computer, make sure it is enable, meaning usb drivers have been installed already. Try to connect on other port.
This is initial troubleshooting.
Let me know how it goes.
Posted on Sep 25, 2011
How do I retrieve my information from a Clickfree backup harddrive that is no longer working?
the clickfree hard drive is the same as any other hard drive and when it fails it has lost everything
there are computer shops that may be able to retrieve the data on the disc but you will have to ring around to find one
try places on the net
Jan 09, 2016 | ClickFree Computers & Internet
How do i restore my files back on my computor
You can either drag and drop files on to the desktop or into a open folder of choice.Or you can right click any file ....copy (this leaves the original on the backup device) and paste into a file or folder.if a file in the computer has been corrupted or deleted then open the folder and copy the backup file into it.never move it because you will lose the backup copy.
Feb 19, 2015 | Click Free Automatic Backup C6 500 GB USB...
Clickfree cannot be fixed because of an I/O device error
Not much you can do except sending it to Clickfree.
Aug 31, 2014 | ClickFree Computers & Internet
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Mar 29, 2014 | ClickFree HD535 hard drive 500 GB USB
Why isn't my clickfree C6 backing up my files on the second time I needed to backup my files it just keep saying that it is backing up but all colums saying 0
It would appear that your Clickfree C6 is stuck on searching when attempting to backup. If you find that the backup is stuck at this phase, where 0 files are backed up and the status reads "searching for files": you should be able to resolve this issue by applying an update from Clickfree's website.
Pre-requisites:
-Administrator rights
-A computer using Windows XP SP3, Windows Vista, or Windows 7 (32-bit, or 64-bit is okay)
-The C6 must be detected correctly by the computer (where both CF_Storage and Clickfree_System appear in Computer/My Computer)
Try the following to resolve the Stuck on Searching issue:
1. Ensure that your Clickfree device is plugged into USB
2. Close any open applications that may be running
3. Using a web browser, navigate to the following address: http://www.storage-corp.com/customerservice/C6_Updater_search_issue.exe
• The website will prompt for a username, use: cssupport
• The website will prompt for a password, use: cssupport
4. When prompted, save the file to your desktop
5. Double click on the file named "C6_Updater_search_issue.exe"
6. The update will take place automatically. Do not close the update application until completion.
7. When the update is complete, click on the OK button
8. Disconnect your Clickfree from USB
9. Plug the Clickfree back into USB
Attempt another backup to see if the issue persists.
Jul 29, 2012 | Click Free Automatic Backup C6 1 TB USB...
Clickfree C2N Won
IF IT DONT WORK MAYBE YOU WILL NEED TO REFORMAT IT.IN THE PROCCESS YOU WILL LOOSE ANY DATA ON IT.
PLUG IN AND FIND IT THEN RIGHT CLICK AND SELECT FORMAT
Apr 10, 2012 | ClickFree 500GB Clickfree C2 Portable...
Clickfree hd 735 manual
Clickfree hd 735 is an external hard drive backup solution. The manual can be downloaded here.
Jan 09, 2012 | Cameras
Trying to run chkdsk on clickfree c2 500gb gives error not enough space on destination drive i am using a dell dimension 3000 desktop pc with windows xp home sp3
how are you trying to run the chkdsk utility
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps you
Jan 01, 2012 | ClickFree 500GB Clickfree C2 Portable...
If you need more help with this post a reply
hope this helps you
I need to format my HD325 click free for mac
I'm sure the OP no longer needs to format their Clickfree C1 HD325 for use on Mac OS X, but I'll answer this question for anyone else who may need a solution.
Before you begin, there are a few things that you should know about Clickfree C1 and Mac OS X compatibility:
-Most Clickfree devices are compatible with Mac OS X 10.5 or higher, but there are some Clickfree C1 devices that aren't compatible with Mac OS X. If your Clickfree C1 was manufactured prior to 2009: your Clickfree C1 won't be compatible with Mac OS X.
-Take a look at the label located underneath the Clickfree C1: if you see WD08xxXM (WD08 is what's important here, you can ignore the rest of the numbers/letters that follow), your Clickfree won't be Mac OS X compatible.
-Formatting the Clickfree C1 using HFS+ will prevent any Windows operating system from detecting the Clickfree correctly. Try formatting the Clickfree in NTFS from a Windows computer for compatibility with both Mac OS X and Windows.
Pre-requisites:
-A Mac using OS X version 10.5 or better
Try the following steps to format your Clickfree C1 for use on a Mac (note that this will erase the contents on your Clickfree C1):
a. Using your keyboard, press the option key + command key + spacebar at the same time; a finder window will appear
b. In the search field located at the top-right of the window, type: Disk Utility
c. Finder will perform a search, and will display the Disk Utility application icon; double-click on the Disk Utility. The Disk Utility application will start
d. Plug your Clickfree into USB, wait a few moments for the application to recognize the Clickfree
e. Click on Clickfree Backup Media from the left side of the Disk Utility window
f. Select the Erase tab
g. Click on the Volume Format drop-down, select: "Mac OS Extended (Journaled)"
h. In the Name field, type: CF_Storage
i. Click on the "Erase" button.
j. Once the erasing is complete, close the application
k. Unplug your Clickfree from USB
l. Plug your Clickfree back into USB
Sep 03, 2011 | ClickFree HD325 320 GB USB 2.0 Hard Drive
ClickFree Backup HD225 250GB USB 20 Automatic Backup Portable Hard Drive Logo
131 people viewed this question
Top ClickFree Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Bill Boyd
Are you a ClickFree Computer and Internet Expert? Answer questions, earn points and help others
