Question about Car Audio & Video
Kenwood car sterio amp KAC622
Power &speaker plug
  • Dan Ford May 11, 2010
    what about the power and speaker plug?
  • 4 Answers
Only use the power plug for the amp
Posted on Oct 25, 2008
Hooking up kenwood cd player in a 2000 silverado but the wires aren't labeled coming out of the cd player. Pls help
If you use a wire harness adapter, you just have to match the colors from the Kenwood plug to the wires in the adapter. No guesswork.
Kenwood uses the CEA standard for car audio wiring:
Yellow: 12VDC constant power
Red: 12VDC key-switched power
Black: Ground
Orange/White: Illumination
Blue/White: Remote output for amp turn-on
Blue: Power antenna activation
White: Left front speaker (+)
Gray: Right front speaker (+)
Green: Left rear speaker (+)
Violet: Right rear speaker (+)
Each wire with a black stripe is a negative speaker output.
You can download owners' manuals from Kenwood's web site.
http://manual.kenwood.com/en_contents/search
Jul 16, 2015 | Kenwood Car Audio & Video
How do i hook up a B4.250.2 Amp to a home sterio?
Hello umbaftroml,
Here's a link to the owners manual: Scroll down to the B4.250.2 and right click "Download Manual".
http://www.lightningaudio.com/scripts/latech.cfg/php.exe/enduser/std_adp.php?p_sid=572kxbvj&p_lva=&p_faqid=154&p_created=1235512138&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OTEmcF9wYWdlPTE*&p_li=
You'll need some source of 12V DC power which is not available on your home stereo. A 12V battery or DC power supply will work OK. You'll also need to wire in a toggle switch to "trigger" the amp to turn on. Just put the toggle switch inline with a diode for isolation between the power wire and the "remote" terminal on the amp. Flip the toggle on when you need to use the amp.
The speaker connections and source connections are all shown on page 6 of the manual and would in any case, be the same as if you were installing the amp in a vehicle. Be aware that most home stereo speakers are 8 ohms, whereas speakers and subs designed for vehicles are usually 4 ohm or sometimes even 2 ohm. This will not be a problem. you shoud be able to drive 8 ohm speakers, they just won't be as loud because the amp will not produce it's full power into an 8 ohm load. Plug your RCA's into your home stereo's preamp outputs, or if there are no preamp outputs, use the speaker level inputs on the lower edge of the amp.
Hope this helps.
Apr 13, 2009 | Lightning Audio B4.250.2 Car Amp
Battery died, Now subwoofer and Amp dont work
on some sterio head units when they lose power u have go into the menw setup and turn the sub controls and adj. back on. this may help if u have not did it all ready /
Mar 15, 2009 | Car Audio & Video
Amp powers on no sound out of sub tested sub on sterio and it works tested rcas fine
test ohms on speakers with volt meter and make sure they match what you bought! subs are blown!
Feb 26, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood new sterio shuts off when turning up volume
You may have a short in a speaker. Check to see that the wire terminals on the speaker itself aren't touching any metal. Even 1 terminal touching metal will cause issues. Hope this helps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
KAC-7202 Major feedback after a few minutes of running.
you might try unplugging the wires from the sub, turn it back on with the wires disconnected- if the noise comes back the amp is probably bad - if the noise doesn'tcome back -turn your head unit off and reconnect the sub- if the noise comes then your sub's voice coil could be shorted- if the noise comes back you should try a different speaker to compare- if the noise still there with the test speaker your problem is definately the amp.
If these suggestions don't help please e-mail me at Merle840@aol.com i will be glad to help. Please give me a good rating if i have been able to help you M. MERLE
Oct 12, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Running amp in house
its very tricky to use a car amp in house, your going to need a power converter and deck for the house, plus car audio is not made for home, the sound is going to be off cause car audio plays a differ frequencys the home sterio.
Nov 12, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Car Audio & Video Logo
294 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
