Question about Hotpoint Ovens
Hotpoint SX995X door removal
I would like to remove the door to clean the insides of the glass, can someone tel me how I can do this, thanks
SOURCE: Removal of door
get a special key and open
Posted on Nov 13, 2007
vest6
  • 196 Answers
SOURCE: Remove Outer Glass Of Oven Door
Depending on the unit there should be several screws on the top and bottom of the door. Thesse screws hold the door sections together. Once the screws are removed the inner glass section should slide out (you may have to remove the bracket screws.) From here there should be some small clips that hold the front glass in place.
Posted on Jan 26, 2008
Master_Tech
  • 770 Answers
SOURCE: KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Posted on Feb 22, 2008
SOURCE: Can't put door back
This may help:
http://www.whirlpool.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196278.pdf?PIPELINE_SESSION_ID=62e5768ec0a8503448ca0e04446c0ca5
Posted on Mar 15, 2008
  • 4 Answers
SOURCE: Hotpoint BD 31 Cooker door
The doors are easy to remove if you know how.!
Where the hinge enters the door itself, there is a little catch which can be turned with a flat screwdriver.
By doing so you prevent the hinge from moving into the door.
Do this on both sides.
Then allow the door to move towards the closed position.
About 3/4 of the way to closing, grasp the door at each side, firmly, and move it from side to side gently.
The hinges will begin to dislodge from the oven frame.
The door will be free to remove and be worked on.
The sealant which holds the glass door to the hinges, needs to be a silicone that is heat resistent.
Silcoset 158 Silicone Adhesive Sealant in a 75ml tube has done the job for me - other brands are available online - but make sure they are heat resistent to 300C
Posted on Jul 25, 2008
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
HOw do I refit the handle on a hotpoint SY36w oven door please?
Most oven doors handles are held in by screws from the inside of the door. Inside the front side of the door, so you need to remove the inside of the door to get at them. You should be able to remove the door from the oven or at least lock it in the down position. Carefully remove the screws and pay attention to which screws goes where. Then remove the back, tighten the screws holding the handle in and replace the back Document or take pictures/video of what you do to make sure everything goes back where it should. Ba careful with the glass.
Jan 21, 2015 | Hotpoint Ovens
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Really how do you get to the inner glass, it has a disgusting line of **** inside i would like to clean thanks
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SOME SCREWS YOU CAN REMOVE LOOK AROUND THE DOOR EDGES FOR SCREWS ALSO REMOVE THESE AND YOU SHOULD BE ABLE TO PULL THE INNER DOOR OFF LOOK MAT THE GLASS CAREFULLY IF THE GLASS IS SEALED TOGETHER WITH ADHEISIVE DO NOT PULL GLASS APART, IF IT HAS A GASKET FINE SEPPERATE THE GLASSES AND CLEAN AND PUT BACK TOGETHER
Feb 05, 2011 | Ovens
How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Oct 24, 2009 | Ovens
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
47 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
