Question about Canon Office Equipment & Supplies
Canon ir 3530 how do I install drum assy? - Canon Office Equipment & Supplies
4 Suggested Answers
  • 1297 Answers
SOURCE: Canon IR 2830 how do I install drum assy?
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it.
B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
Posted on Nov 22, 2009
  • 58 Answers
SOURCE: E000002-0102
this is a fixing unit malfunction code you need a new fixing unit
Posted on Aug 07, 2009
muleskinner2
  • 270 Answers
SOURCE: I am using Canon IR
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Posted on Jun 22, 2011
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
E000732 0001 error in ir 3530 how can i solve
Official instructions from Canon are these, try if it works for you:
Solution 1:
  • Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
  • Solution 2:
  • Check all the connectors on the main board.
  • Solution 3:
  • Unplugg and replugg all the leads between the boards and modules
Dec 26, 2016 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Display touch is very hard
my printercanon ir 3530 insaid disply was rain water in said but how to open and cleen the disply bord tuch screen
Dec 15, 2012 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Service support tool DLMO ver. 1.25E canon ir 3300
hi I have a probelm with installing hard on my Ir 3530 coper
I need software of this machin
How can I download it ?
Thank you
Jan 19, 2012 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon IR 2830 how do I install drum assy? How do I put in a drum unit for the IR 2830.
Nov 22, 2009 | Office Equipment & Supplies
136 people viewed this question
old marine
old marine
