Question about Hotpoint Washing Machines
Water is leaking from my Hotpoint WF620 detergent drawer
  • 1294 Answers
SOURCE: LEAKING DISPENSER DRAWER
Refer to your manual regarding the dispenser tray. You could try using a tooth brush to clean out dry detergent, which could be blocking the flow of water. You can take out tray to clean, ref manual.
Posted on Jan 13, 2008
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
barkencoa
  • 3463 Answers
SOURCE: Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Posted on Feb 02, 2009
SOURCE: whirlpool duet washer leaks from
We just had the same problem. We took off the three screw on the back to remove the top panel on washer. From there we took the screws off the electric face plate on the front. Be careful, there is a screw located inside the door. You must open the door to get to the screw. Next we removed the bottom panel door and then the four screws to the mail metal panel on the front. Hold that panel because the rubber gasket is still connected. Then you will see a rubber hose directly under the drawer. Take the rubber hose off at the bottom nearest the drum. We found a sock that had wedged itself up and was causing a back up. After I cleared it, the washer works just fine.
Posted on Nov 09, 2009
apart4u
  • 213 Answers
SOURCE: Hotpoint WD860
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
Posted on May 06, 2010
Hotpoint soap drawer leaking, wfooo
The problem is not a leaking soap container. The problem is that it is overflowing because the line from it to the washer tub is clogged. This happens mostly when using powdered detergents. Check you operating instructions for soap dispenser cleaning procedures.
Jan 03, 2015 | Hotpoint Washing Machines
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
Water leaking from detergent drawer Hotpoint WMD 962
what is your model number is then we can get started then okay
Feb 04, 2013 | Hotpoint Washing Machines
My Hotpoint WDL 540G washer dryer is not filling the detergent drawer and the wash is going through without cleaning properly. We had an initial problem with the lights flashing but managed to sort that...
Is the water switched on? If it is try a cold wash only and if it works then the problem will be with the hot water valve either blocked or valve may be faulty.
Dec 28, 2012 | Hotpoint Washing Machines
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Leaking water
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
Oct 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
