Amana Air Command 90 furnace wont do anything red light flashes
The furnace does'nt come on,even when you turn the thermostat up.There is a red flashing light and a little bit of water standing under control panal
Therinnaiguy
  • 1420 Answers
SOURCE: Amana 80SSE Furnace
Not much info to go on, but lets look at a few possibilities. Your thermostat could be turned to the ?Fan On? setting, make sure you put it in the ?Auto? mode. Or it could be bad, or there could be a short in the wiring. Open up the access panel on your furnace. Lets eliminate the thermostat from the equation by disconnecting the red, white and if you have a yellow wire at the furnace. Mark down which wire went where. The furnace will have a door safety switch that will have to be taped temporarily closed to test the furnace. With a short piece of wire (2-3" long), strip off 1/2 inch of the insulation on both ends. Secure one end on the R terminal where you removed the red wire from your thermostat. Take the other end and touch the G terminal on the same electrical board. Your fan will start. Don't worry about an electrical shock, the voltage is only 24 volts. Now with one end still attached to the R terminal, touch the W terminal where the white wire was attached. The furnace will now try to fire up. Hold it there until you see that it did start. If you did this and had success, I would say it was your thermostat or the wire going to it. Last resort would be a bad control board. If you want, you can do test your thermostat wiring by removing the thermostat from it's mounting plate. Put all wires back where they were on the furnace. Make sure the access door is back in place and secure. Take that same jumper and jump across the red and white wires on the mounting plate. Again the furnace should start up. Have a helper jiggle the thermostat wires where accessible when the furnace is running and see if it remains on or shuts off. If everything checks out, replace the thermostat. Good Luck!
Posted on Oct 08, 2007
koolbreezes
  • 540 Answers
SOURCE: i have an amana air
This unit goes in steps, 1-- thru--4 Step 1, vent fan blower motor runs & prove thru the air tube, which closes a switch and tells the circuit board to go to step---2 Step 2 lights the glow plug and goes to step 3 automatically, Step 3, opens the gas valve and send in gas thru the long venturi tubes which lights from the glow plug and on the last tube, theres a rod that sticks into the flame, if no flame or not working properly, it will shut down the starting sequences and retry for 4-times and automaticaly lockout till unplug and start over. (whever step it stops at, then thats where your problem is!
Posted on Sep 06, 2008
huuum
  • 750 Answers
SOURCE: Amana Air Command 80, 20
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Electronic ignition.
Furnace does not start.
Good power to furnace.
Thermostat properly set.
Where do I start looking?
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Posted on Oct 13, 2008
SOURCE: My Thermostat is flashing "L6"
The battery needs replacing.
Posted on Oct 18, 2008
  • 182 Answers
SOURCE: amana air command 90 model
It may be a delayed ignition.Try removing and washing the burners.
Posted on Nov 02, 2008
Furnace comes on but wont stay running,when it shuts off a red light flashes
What light is flashing Red? Is it on your thermostat or is it a red light inside the package unit at a circuit board?
Oct 08, 2013 | Intertherm P3RA-048K Air Conditioner
Furnace problem
SHUT THE POWER OFF TO THE FURNACE, REMOVE THE THERMOSTAT FROM THE THERMOSTAT SUB BASE TAKE THE WIRE THAT IS ON THE R TERMINAL AND THE WIRE THAT IS ON THE W TERMINAL AND CONNECT THEM. TURN THE POWER BACK ON. IF THE FURNACE COMES ON AND WORKS FINE THEN ITS IN THE THERMOSTAT.
May 30, 2017 | Heating & Cooling
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
Dec 31, 2009 | Heating & Cooling
Amana 80SSE Furnace
Oct 08, 2007 | Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
