Question about Whirlpool GBD307PRS Stainless Steel Electric Double Oven
My whirlpool GBD307 double convection oven is making noises like the fan may be ratteling? What do I do? Is it the fan or something else??
The same noise happens if I turn on the bottom oven also.
applianceboy
  • 77 Answers
SOURCE: Whirlpool Double Oven GBD307
there are three possible issues, one is a faulty ground. the computer uses ground to determine zero in binary logic. It could also be a stuck key on the input board, or the main control board. Check your owners manual, some units come with an exceptional warranty on the electronics. This is a big one and it may be worth your time to call a tech in to check it out. electronics are expensive and you can not send them back if you diagnosis is wrong.
Posted on Sep 25, 2007
barkencoa
  • 3463 Answers
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
TheRepairGur
  • 27 Answers
SOURCE: Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Posted on Apr 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: After taking my Built-in Electric Convection Oven
Use this handy GUIDE
Posted on Dec 25, 2010
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Noise when oven running and stops when oven stops
Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
Dec 02, 2013 | Thermador SC272T Electric Double Oven
GE double convection oven model GBD307 has stopped working.
my bake element stop working it is hidden and can't find out where i need to replace it,whirpool can you help
Dec 19, 2009 | GE Ovens
Frigidaire Oven making vibration noise when Pre-Heating or Convection cooking. Only notice when convection fan is running.
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Dec 11, 2009 | Frigidaire PLEB30S9DC Electric Single Oven
RepairClinic.com
asplogo.jpg?ver=23
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Need help replacing the Broil Element in our Whirlpool Dbl Oven GBD307
It is easy to replace.   Turn power off to the oven.    Remove the screws holding the element to the inside of the oven, Carefully pull the element out of the oven liner until you can unplug the wires from the element. Hook up your new element and ease it into place and re-install screws.
You can get the part from any whirpool servicer or you can order it from Sears.
Oct 13, 2007 | Whirlpool GBD307PDS Electric Double Oven
Sep 24, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool GBD307PRS Stainless Steel Electric Double Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
