Question about Pioneer SX-315
No sound I have no sound from my pioneer sx-315s. The speakers have been tested and they are fine.
I just fixed mine. Plug in your head phone. wait couple of seconds. you will hear clicking noise which seems to reset the receiver. 10seconds later, sounds should come on and if not unplug the head phone and you should hear it then.
Posted on Nov 15, 2008
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
I have tv hooked up to the pioneer but the TV will not play its sound through the speakers? what Am I doing wrong? I have the DVD hooked to the Pioneer and it works fine.
Is the unidentified TV a sound source from the SX-315's perspective? Is it's audio output enabled whene the TV volume is down? Would the Cable Box be a BETTER source?
Jul 26, 2011 | Pioneer SX-315
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
No sound from my speakers
Check your Surround Settings (Make sure you are in Full surround and not 2 ch) as well as your Input Source Remember the Surround Speakers will not give you a Full Audio Output it will only give you "background noise"
Sep 27, 2008 | Pioneer SX-315
Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Mar 07, 2008 | Audio Players & Recorders
Pioneer SX-315 Logo
257 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
