Question about Dishwashers
Do i have to use dishwasher salt in my blomberg dishwasher?
2 Suggested Answers
murdozzz
  • 41 Answers
SOURCE: Hi. Just bought a Blomberg
you will find the correct type of salt on the same isle as the detergent in the supermarket.
Regards
Ian
Posted on Apr 20, 2011
I can not get my dishwasher to start Blomberg
sadly without my teleporter i can not test your machine to tell you the possible problems
Jul 14, 2018 | Blomberg Dishwashers
Blomberg dishwasher Tube from fill chamber came off I secured it Then the tube to the sump came off They have small squeeze clamps
Use proper screw down hose clips. They use the squeeze ones for cheapness and speed of assembly. Change them all and save the worry of floods.
Nov 27, 2016 | Blomberg Dishwashers
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
Dishwashers Logo
125 people viewed this question
Top Dishwashers Experts
