Question about Aiptek AX4 MP3 Player
Orange Light I have the Aiptek AX4 MP3 Player. When I plug it in or when i push the button to play, it shows an orange light (both the green and red lights on at the same time). It isn't recognized on the computer, and it won't play the music. This is happening to mine and in the past it has worked. However, we just got one for my dad and it is doing the same thing, it never worked. I've tried different sd cards in it and it is the same. I've emailed aipteks help center and still have not received a response. Can you help me? Thanks
4 Suggested Answers
SOURCE:
zappa
  • 44 Answers
SOURCE: transferring mp3 files from memory card onto computer
The DV4500 comes with a cd that has all necessary drivers, and I think you can simply install the one you are missing. Also, be sure to FORMAT the camera's memory card first, it can't recognize the mp3s until you do. that particular driver you requested is downloadable from Microsoft, and the troubleshooting in the back of the manual tells you how to do it. That should let you transfer mp3s. Good luck.
Posted on Sep 11, 2005
  • 21 Answers
SOURCE: Wont read sd card..screen shows card locked..card ok
Aiptek is not so good at answering emails. If Nitrotrike's suggestion doesn't work, try posting this question at
http://forums.steves-digicams.com/forums/view_forum.php?id=92
Those guys are more likely to help you (or at least try) more quickly than Aiptek.
Posted on Jan 19, 2008
  • 1288 Answers
SOURCE: How to make Aiptek HP 12000U show up on computer
This needs a driver for Windows XP, which can be downloaded from Aipteks site. As I recall, you install the driver before the tablet and let XP "find" the hardware and install it.
Please clarify which OS you are using
Posted on Feb 10, 2010
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
Feb 17, 2011 | Apple iPod shuffle Second Gen. Silver (1...
Can't turn on ipod shuffle
Try To Plug It Into The Computer.. This will Sometimes Turn It Back On
May 06, 2010 | Apple iPod shuffle Second Gen. Silver (1...
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Feb 19, 2010 | Speedo Aquabeat MP3 Player i
When i try to put sons on my ipod they show up on my computer screen so that it looks like there are songs on it but when i disconnect my ipod shuffle the songs dont play and a light flashes green red...
Are you sure its green red green red or is it green orange green orange?
Because according to apple, it doesnt have a sequence for green red green red..... either way, you can see what the different lights mean here..
http://support.apple.com/kb/HT1407?viewlocale=en_US
Thank you and please be sure to rate this answer... :)
Sep 24, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod shuffle
same has happend to me but i now have an ipod nano but i suggest you go back to using itunes
Aug 23, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipad is not working
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jul 07, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Shuffle not working, blinking green-yellow led.
blinks green.
Jun 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Red and yellow flashing light
blinks green.
Dec 27, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Aiptek AX4 MP3 Player Logo
37 people viewed this question
Top Aiptek Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Aiptek Audio Player and Recorder Expert? Answer questions, earn points and help others
