Question about Dryers
Hunter fan model 25450 wiring diagram - Dryers
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
  • 5 Answers
SOURCE: hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Posted on Aug 14, 2008
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
Hunter 30027 need wiring diagram
Is this a ceiling fan? I don't know that number. Wiring diagram for what?
Jul 01, 2015 | Hunter Dryers
Wiring diagram for hunter fan remote part 98480-02
Red and white go to the wires in the ceiling. Black and white go to the motor and the blue goes to the lights.
Sep 08, 2014 | Hunter Dryers
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter fan
call the manufacturer at 1-888-830-1326
Aug 25, 2013 | Dryers
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Need a wiring diagram for thermostat/hunter model44260
Sep 04, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter Ceiling Fan 25885 remote won't turn off light
I have this fan model. The RED is a common wire. Wire it in with all the white wires. Better yet why don't you just bypass the module for the light. You could buy a more up to date Lutron wall switch W/remote control. The Black wire W/White stripe coming from the module is the light control. Cut & cap this with a wire nut. The same wire coming from the fan motor Connect it to your new wall switch. Now heres the tricky part. You have to run a new (Non switched) hot wire to your fan this will connect to the module normally. This is the new power for the fan. The remote that comes with the fan can serve as the On/Off 1,2 & 3 speeds. You now have two remotes. One for the fan the original and one for the light control w/wall switch. The new Lutron model will give you full dimming capability for incondesent bulbs. It is much less noisy when you are dimming the light down.
Jul 24, 2009 | Hunter 28486 Ceiling Fan
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter fan programmable thermostat
Need more information about tstat model number what type of a/c and heater do you have..heat pump, gas furnace, electric heat. Also what wires are connected to the tstat and to what position on the tstat. I have included a link to hunter's user manual page for tstats. The wiring diagrams are there just enter your model number and click submit. Good luck Kevin
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Dec 29, 2007 | Hunter Fan Company 5/1/1 Programmable...
Dryers Logo
178 people viewed this question
Top Dryers Experts
