Question about Zanussi Washing Machines
Fault code E62 on zwg 1140m
Fault code E62 has appeared on digital display during cycle
redbeard00
  • 957 Answers
SOURCE: C1 keeps popping up on display during cycle and wont finish. what do i do?
C1 isn't the code, it is a warning that a problem has been detected with the ABS system.
Posted on Apr 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: fault code
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: I get an F1 fault code during the fill cycle. Can anyone help us?
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
  • 1417 Answers
SOURCE: washer code H and F
hello,
What this simply mean is that there has been an over flow of water flow in to the panel i.e the power control of the washer .some time this affect the spin cycle or drum.
thanks
Posted on Dec 04, 2010
caroldon
  • 17130 Answers
SOURCE: zanussi 1140m stops half way
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jul 19, 2011
Whirlpool duette washer stops during cycle beeps and displays error code F
The f should be followed by a digit or two that indicate a particular fault code. A mid cycle stop with a fault code might be because of a long drain time due to a
Faulty drain pump or clogged drain filter but without the entire fault code it’s difficult to give an exact answer.
Feb 11, 2018 | Whirlpool Washing Machines
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Turns on. Fills with water, then why does it display error code e60?
Someone posted a list of codes: Error code e60 zwg 1140m
Some people say they just pressed and held the reset button for 5 seconds.
Nov 26, 2015 | Zanussi ZWF1430W Front Load Washer
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Jan 11, 2015 | Zanussi Washing Machines
Heating time out. Could be heating element.
Dado
Sep 12, 2014 | Zanussi Washing Machines
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
E62 code on display
E62 - Power relay to heater unit faulty
Could be:
  • Heater unit faulty.
  • Wiring faulty.
  • Electronic board faulty.
At this fault appliance forced cooling cycle.
Dado
Mar 11, 2014 | AEG T57800 Electric Dryer
WASH MACHINE NOT WORKING RIGHT
E62 Overheating during washing --- Drain, end of cycle.
Try changing temperature or cold wash.
Click if helped pl.
Apr 24, 2013 | Zanussi Washing Machines
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
