Question about Homelite Garden
How to adjust carburetor on homelite super wiz 66 chainsaw
  • 149 Answers
SOURCE: need to adjust carburetor jets of homelite chain saw
a small flat blade screw driver will do most of them some may have limiter cap which can be pulled off other types have a splined shaft but only find them on Huskys.
Posted on Jan 12, 2009
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 708 Answers
SOURCE: my homelite super 2 chainsaw keeps flooding. it
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to homelite.com to find manual for the saw.
Posted on Apr 16, 2009
  • 120 Answers
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Posted on Jun 20, 2009
  • 376 Answers
SOURCE: what is my lo hi carb adjustment for a homelite
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Posted on Jul 01, 2009
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelite super 2 carburetor
There should be a screw next to the carburetor, and by turning it you can adjust the idle speed.
Sep 29, 2013 | Garden
I have a homelite super xlao chainsaw that will start up ok. But it will not rev up. I have replaced fuel line,filter and cleaned and rebuilt carborator and none of this has helped. Any advise would be...
You have done the normal things (good on you). Remove clean and reinstall the muffler and spark arrestor (it cannot inhale if it cannot exhale). Replace the plug because it could not hurt and is inexpensive. If no better try to tweak the carburetor settings. This is the best description I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH
Lou
Feb 14, 2010 | Homelite Garden
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Jul 01, 2009 | Homelite Garden
Garden Logo
190 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
