Question about Compaq Presario 5000 PC Desktop
Compaq Presario V6000 screen problem
Essentially, when I open my laptop, the bottom fourth of the screen is showing interference lines and that portion of the screen does not show the images on the default bootup interface. At times the lower portion is blacked out completely.
The problem is becoming increasingly worse.
My computer...don't even know if i have a warrenty...but only a couple of years old.
HELP, this computer was a replacement when my large screen HP blew up 3 times and was replaced twice then they finally aquiesed and gave me this...it was great until just recently...but situation is depreciating quickly...Ugggghhhhh....
  • julescm Oct 24, 2008
    When rebooting I pressed f8 and nothing happened. Do I also need to press the fn button to activated the f8 button?
    So computer is not in safe mode at this time.
    I did go to the control panel and change the resolution to 1024X768 but did not have to change the hz to 60; it was already set to 60hz.
    The problem seems to be resolved but do I still need to put the computer in safe mode and if so, how do I do that?
    Thank you for your help.
  • 108 Answers
When booting up press f8, go into safe-mode. See if the screen still behaves the same way, If so... I don't think there is much that can be done except using an external monitor on the laptop.
But if it looks ok, I would set the display settings resolution to 1024x768 and freq. hz to 60
In safe-mode you may not be able to set to 1024 but have it set to something in safe-mode so when you reboot it the normal mode it will have reset some of the display settings and hopefully fixed that for you. If the problem persists, check on the freq hz setting and try to go as low as possible, probably 60hz.
G'luck
Posted on Oct 24, 2008
  • Jerry Oct 24, 2008
    I researched a little more - Try this for safe mode, but if the issue is fixed, I would not bother with safe mode now... but for future reference....
    To get into the Windows 2000 / XP Safe mode, as the computer is
    booting press and hold your "F8 Key" which should bring
    up the "Windows Advanced Options Menu" as shown below.
    Use your
    arrow
    keys
    to move to "Safe Mode" and press your Enter key.
    G'luck
Black screen v6000 laptop "HELP Please"
It appears the hard disk has been wiped/formatted and does not have an operating system installed.
You need to get a Windows Vista installation CD and if the Windows label on the bottom of the laptop is still attached then this label has the product installation code.
Boot up with the Windows Vista installation CD to install the Vista operating software then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 19, 2012 | Compaq Computers & Internet
I have Compaq V6000 series laptop with AMD Processor & nvidia graphic card ,my laptop?s lower half of screen becomes blurred & will become ok after some adjustments & again become blurred when...
There was a TSB about the motherboards on the V series describing severe video issues and Nvidia GPU failures. Many consumers got a motherboard replacement. Try using a laptop cooler in the meantime and see if that helps a little. Also try googling V6000 video and see how many others got nuked by this poor design.
Mar 13, 2010 | Computers & Internet
Presario v6000 thes screen will not work
If the laptop appear to boot up (ie the hard disk LED flashes) but you cannot see an image on the screen, then you could have a backlight problem.
To determine the actual fault, please follow my instructions which are on this link :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 16, 2009 | Compaq Computers & Internet
I need for my compaq presario v6000.
You can get the wireless drivers in the laptop itself. U need to type in the start search as recovery manager and when the window is opened, click on the advanced options and select the option hardware driver installation. Search for the sound driver and select it and it get re-installed. If this doesnt work try to go to hp.com and select support and drivers and enter the product number of the laptop and follow the onscreen instructions.
Thanks and Regards
Honey
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Screen replacement for a compaq laptop model presario v6000
Search ebay for presaron v6000 lcd screen. You can buy it from there.
Nov 12, 2008 | Compaq Computers & Internet
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 6000 Monitor Problem
sounds like your lcd screen is on it's last legs...time for a replacement..
Jun 01, 2008 | HP Compaq Presario V6000T Notebook
Black screen
my presario v6000 laptop doesnt starts it shows desktop
Apr 11, 2008 | HP Compaq Presario V6000T Notebook
Screen stays black
Your inverter board is bad. It is time to change it.
This manual page 152 will show you what is involved.
http://h10032.www1.hp.com/ctg/Manual/c01035886.pdf
Mar 19, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 5000 PC Desktop Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
