Question about Konka K2001UM TV
Once the TV is turned on, it immediately begins to flip from channel to channel by itself. Also, the TV no longer responds to the remote control.
    New Friend:
  • 163 Answers
Check for a clogth chanel button, is very rare, but in the past, I solve this problem by changing that switch, is a job for a tech not for regular people remember, there are many dangerous circuit in a tv.....good luck
Posted on Aug 11, 2006
  • hector delacruz Aug 11, 2006
    just in case, did you remove the batery from the remote control?...
Fuente dañada
Posted on Mar 29, 2008
SOURCE:
INSIGNIA NS 19E310A13 after setting channel favorites will no longer respond to any controls
go into the setup menu and reprogram the channels using the controls on the tv itself..if its more than 2 years old, get a new one..repair costs are more than a new set is..
Mar 15, 2014 | Insignia Solutions NS-19E310A13 19" LED TV...
I need the code for a sharp tv on a guestvision universal remote?
Probably your best bet would be to perform a channel search. Make sure the TV is on and press and hold down the "Code Search" button. After the red light comes on, begin pressing Channel Up until the TV responds. This could take a very long time, but should eventually work. Once the channel changes on the TV, go ahead and press the mute button on the remote and you should be set!
Aug 25, 2011 | Televison & Video
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
I have a Dynatron DYN100Z remote I need to set it for a Symphonic TV . It has worked on this TV before. I lost the code.
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on. 3. Click the (+) Channel button once each second, until the TV responds by flipping a channel. 4. One the channel changes, press the, "ENTER" button. 5. Code is saved!
Jan 07, 2010 | Televison & Video
Code list forToshiba television is ineffectual
You tried all of the following codes?
018,021,023,071,085,090
Doing as follows
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Try this if so
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jan 08, 2009 | RCA RCR311B Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
TV Stuck in TV Guide Plus+ Installation Mode
buy a good universal remote and it will have the correct button, that's what I did, I got the Radio Shack 8-in-1 remote and programmed it and it got rid of it.
Dec 03, 2007 | Mitsubishi CS-36609 36" TV
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
182 people viewed this question
Top Konka Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
