Question about Home
Need to replace bellavista style toilet seat - Home
4 Suggested Answers
  • 102 Answers
SOURCE: I have a square shaped toilet and need to replace ...
Check with your local plumbing supply houses. I believe Kohler and Eljer noth made square front bowls at one time. I hope this helps.
Posted on May 21, 2010
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
SOURCE: Need to order a replacement toilet seat for Model
I have problems with booths of my toilet seat.
When sitting down it move's & every think is tide .
My question is WHY ?????????????? It is also very unsafe, you feel like you will fall of the seat.
Posted on Aug 18, 2010
Trying to find a replacement toilet seat for Bellavista Stylo white toilet in Sydney Australia
I had this problem also. Reece Plumbing sell replacement soft close seats, as do Bunnings. Also call Ostar International116 Milperra Road, Revesby NSW 2212 Phone: (02) 9773 3788, to see if they can assist.
Make a cardboard outline of the top of the bowl to match the geometry.
Oct 02, 2015 | Home
Where can I find an American Standard replacement toilet seat? I need the elongated style in Bayberry color.
If this is an old color from American Standard, you might not be able to get it anymore. Contact the manufacturer to find out how long ago they discontinued it.
Oct 11, 2014 | Home
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
Bellavista stylo toilet
Hello.
I live ind 18690 Almunecar, Andalusien, kan you help me with where I can by a new toilet seet.
With Kind regards
Mogens Madsen
Jun 06, 2013 | Home
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 14, 2010 | Eljer Toilet Seat Tosca 124200000
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Nov 17, 2010 | Duravit Tribeca US-Type Elongated Toilet...
My toilet seat broke, where do i geta replacement?
Unless there is something unusual about the seat you should be able to buy a standard replacement seat at Home Depot or Lowes. They come in round and elongated and there are a number of styles available. Measure the distance between the center of the mounting bolt holes and match with the display to see if they will work.
May 24, 2010 | Neptune FB1635 Catania Toilet
Home Logo
380 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
