Question about HP OfficeJet r60 All-In-One InkJet Printer
Hp officejet r60
Black cartridges don't last as long as they used to - cartridges still seem half full but won't print - pages come out blank until a new cartridge is installed - never had a problem with this before I used a few low end, off brand cartridges - Now, it seems like going back to the factory HP cartridges didn't help either. Is there a cleaning solution that might improve my ink problem.
    Novelist:
  • 67 Answers
Hi gandoman,
It's possible that the problem might be that the ink nozzles of your printer is clogged. Have you tried running the diagnostics for your printer and running the nozzle cleaning option with the HP tools software. Try running the nozzle clean for like 2-3 times to make sure that the ink nozzles are not clogged, then print a test page.
Now, well most inkjet printers have catridge cleaning solution to de-clogged nozzles. As far as I know Epson and Canon has one, I'm not sure about HP, you may have to check on this. I'm also going to look around for this.
Hope this helps for the mean time.
Peace! :)
Posted on Oct 24, 2008
  • 507 Answers
This might happen if you have used hp branded ink cartridges before and now then used refills then getting back to hp branded cartridges.
i think the best way now is diy
refill the ink cartridges yourself
http://www.hornetcs.co.uk/prod/ih/HP/Officejet_R60.php
http://www.gotink4u.com/ink/cartridges/60390.htm
  • 849 Answers
It is always better, use the appropriate cartridge or the recomended one, if you got some other then alliignment should be done in less frequency.
hope it will solve your problem.
p.s.
use the recommended cartridge
  • 108 Answers
In my experience, if an inkjet gets to be over 2 years old and starts having issues, especially with ink cartridges (due to the expense)
The printer should be replaced. Ink jets and deskjets are considered "disposable".
You may not find a good solution to fixing something that was made to be thrown away in a year or two. Save money on ink and buy a new, cheap printer for another 2 years. Sorry, thats just the way they make them and have been making them. You honestly can buy a new printer that comes with ink cheaper than trying to fix your old one and or keep replacing ink in an old one that does not work properly.
G'luck
    Master:
  • 505 Answers
You can use Sainsbury Bathroom cleaner which is very good.
Process to clean your printer which is the main reason for wastage of ink :
  • Turn on printer - head moves across
  • Pull power cord so the head is left 'unparked'
  • Spray cleaner onto the parking pads
  • Carefully soak up spray with kitchen roll
  • Repeat if there was a lot of dried up ink on the pads
  • Spray again - leave the pad soaked with the cleaner
  • Turn printer on, let head return.
  • Switch printer off with it's own power button
  • Wait overnight :-)
You can get cartridges full of cleaning solution but I prefer to get an old empty cartridge and add a few cc of isopropanol to it through the vent tube (this is a fiddly operation and needs a syringe). This cartridge now has very dilute ink/solvent in it. Run some test prints and see if the clogs go away. The very dilute ink and solvent is much easier to see on paper than pure cleaning fluid.
  • Indrajit Roy
    Indrajit Roy Oct 24, 2008
    You will get Printhead solutoin kit from any local store or bestbuy. These kit are very useful for cleaning your printer head
  • Indrajit Roy
    Please let us know if the problem is resolved or not.
    Thanks
    Genius:
  • 1,268 Answers
You need to clean the head printhead. First try to use the diagnostic tools that was installed using the disc of your printer, the printer utility/software. Use the self cleaning utility like nozzle check and the likes. The link HERE is the cleaning instruction but it's not for the same printer model. It might help you.
How do i change the cartridge
See below: Also is a link the the manual for your unit the maunal has pictures: Page 62 of the manual list the procedure. (page 72 in the adobe file)
Manual
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
Feb 25, 2011 | HP Officejet 5510 All-In-One Thermal...
Black ink cartridge almost empty in just two days of use..why?
its all in simple math, when you go to by new ink cartridges it should tell you how many pages on average it should be able to print so price/page*15=cost to print a day
Feb 09, 2010 | HP OfficeJet J4580 All-In-One InkJet...
Hello, My name is Cherie Hefty. I have an Hp Officejet 5610. I am having problems getting it to print anything. Everything was working properly until I had to switch the black ink cartridge because it was...
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr14
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
HP J4580 Printing blank pages
fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Apr 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 6110 all in one
I know this sounds dumb, but alignment pages use the color cartridge to make black print. Are you sure your black cartridge is working? and what does the windows test page come out looking like?
Aug 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet r60 All-In-One InkJet Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
