Question about Motorola Walkie Talkie 2-Way Radio
Need a user manual badly for K7GEM1000 = FCC-ID or inside radio number states IC:2415B-EM1020 the walki taki will turn off after you key the mike and talk with someone else please help thanks Ron at
Radio will shut down after keying the mike talking to somone eles and need a service maual FCC IDK7GEM1000 or inside radio states IC:2415B-EM1020 thanks Ron at cmercy@eagle.ca
2 Suggested Answers
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
I need instructions on a Motorola walkie talkie FCCID K7GSX900
Go to the following web page and download the manual: http://www.manualdisk.com/pdf-/motorola-walkie-talkie-fcc-id-k7gsx900-range/
Mar 04, 2015 | Motorola Radio Communications
How the heck do you put in the ear phones for this walkie talkie -- there is no hole to put the plug ?in
If there is not hole for an earplug/earphone, the radio does not provide that capability. Most of these types of radios do not support earphones.
Jul 26, 2014 | Motorola Walkie Talkie 2-Way Radio
How to repair ic-v8 tuner
In the USA, repair and service of a radio frequency transmitter requires a 1st, 2nd, or 3rd class FCC license. The other bad news is the radio probably uses a solid-state chip for tuning, so special tools will be needed to remove and install a new chip. This is best left to a factory repair center.
May 22, 2014 | ICOM Informatique Radio Communications
NOT WORKING 2 WAYS ONE SET SEND AND RECIVE ANOTHER ONE ONLY RECIEVE MOTOROLA WALKIE TALKIE fcc id k7GSX900 UPDATE
Check your programming. It is possible one of them has a different PL (aka code or interference eliminator code) than the others. Here is a link to the user guide page where you can select your model from the pulldown. http://shop.giantintl.com/Manuals.asp Look at the section about programming and turn off any special features, taking your radio back to a very basic mode, matching all setting between the radios. This should make your radios communication easily together. If not, you may have one bad radio in the mix.
Best regards.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
Connect cw to IC-735
The ic-735 has to have the keyer option to use with a paddle, if it doesn't you will have to use an external keyer with it
Jan 17, 2014 | Radio Communications
Blown fuses on galaxy dx 939 after holding mike switch for less than ten seconds
try to key it down without the mic attached and see what happens.it could be in the ic or even the final so be prepared to replace them
Nov 19, 2013 | Galaxy Radios DX 939
I have an icom radio and my friend a zartek 708. Will we be able to talk to each other
The answer is yes (sort of), PROVIDED BOTH OF YOU obtain at least a Technician-class radio amateur license from the Federal Communications Commission (FCC). To get this license, you will need to take some classes, then pass a 35-question mulitple-choice test. You will learn a LOT about your radios, and radio in general, in those classes. Many of the classes are free.
Once you've passed this test, you will get your own call letters, which must be used to identify your station (walkie-talkie). You will be able to talk to other amateurs as well as your friend. You will get a lot of other privileges, too. As for the radios, you will need to have them programmed to the same frequencies, to enable you to talk to each other.
Contact the American Radio Relay League (ARRL) for information on classes in your area. Talk to hams you might know. You could be on the way to a wonderful hobby...or even a career, if you take it that far!
Notice I said, "sort of". These radios would both need to be programmed to the same simplex frequencies, to enable you to talk to each other. As such, you would find them of limited use on the ham bands, and you would soon want something a little better, to enable you to talk over repeaters as well as simplex (radio-to-radio). Fortunately, there are some quite-inexpensive handie-talkies available. Baofeng and Wouxun come to mind. I have a Wouxun, and it works quite well.
A word of caution: Do not transmit on the Icom without a license and having it programmed to appropriate frequencies. Also, make sure the Zartek is programmed to GMRS frequencies before using it. DON'T (that is, DO NOT) mess with the FCC, as FCC fines routinely run to the thousands of dollars!!!
Finally, if you just want to talk short distances, you can buy GMRS/FRS radios from places like Big 5, etc, for not very much money. You might not be happy with them for very long, though.
Nov 11, 2013 | ICOM Informatique Icom IC-F21 16ch UHF...
Inline fuse blows when mic is keyed and talking
either wrong size fuse or wires are touching inside mike when keyed
Sep 09, 2013 | Radio Shack Radio Communications
Radio Communications Logo
288 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
