Question about Frigidaire PLMB209DC Microwave Oven
My Frigidaire Microwave PLMB209DCC sparks when I turn it on
At first I had to replace the door switch on my microwave to make it heat and the carousel turn and now it does both but it sparks and smokes now!
MicrowaveSvc
  • 9085 Answers
SOURCE: microwave door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
SOURCE: Frigidaire FMV156D 950 Watts Microwave
check or replace magnetron
Posted on Nov 09, 2008
pyledriver
  • 7 Answers
SOURCE: I think I have a bad door swtich on a frigidaire microwave
un plug the oven, un screw the screws and remove the cover, look behind the door where it closes and you will see a micro switch, and two wirers, note where the wires and screw is located and remove them. get a replacement switch NOTE!! make certain that it is the same type of switch ie. normaly open or nomaly closed. carry the switch you to get the replacement. replace the switch and the wires. if you want to verifry that the switch is defective you can have it tested when you go to the spares store to obtain the new one.
Posted on Jan 05, 2009
  • 38 Answers
SOURCE: Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Posted on Mar 15, 2009
  • 38 Answers
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Posted on Mar 20, 2009
How to fix loud hum and no heating in Sharp model R-308KW?
There could be a variety of reasons why this happens, but the likeliest
reason is the secondary interlock or monitor switch is broken. These are micro switches that tell the microwave that the door is closed. If this switch is broken, then the microwave thinks the door is still open and the carousel table won't turn, and the oven will not heat up.
I replaced an interlock switch last Saturday. The switch was $7.00 and took me an hour.
Ask your local repair person to test the interlock and monitor switches first, then go from there.
Good luck,
Hank
Jul 09, 2014 | Sharp R-308KK / R-308KW 1100 Watts...
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
Frigidaire microwave stopped heating
The problem of not heating is most likely the door interlock switch. The 'primary' one goes bad the most often. On some microwaves all the interlock switches are in a cluster and must be replaced together and on other microwaves the switches are individual micro switches.
Oct 17, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
I don't hear the fan, the carousel doesn't spin, nothing works but touchpad & light
It sounds like you may have an intermittent door switch or loose door switch mount.
Does it work differently when you wiggle the door?
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 19, 2007 | Sharp R-408HS Microwave Oven
Microwave does not heat
check the control panel and related circuit,and check the door lock switches ,..
Sep 27, 2007 | Roper MHE14XKB Microwave Oven
Frigidaire PLMB209DC Microwave Oven Logo
132 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
