Question about Mazzer Coffee-grinder SUPER JOLLY Electric
Just bought a mazzer super jolly grinder, used it once, the grind was too coarse (#6), adjusted it to a finer grind ((3), and the next time i ran it it stopped grinding, the motor is on, the grinder turns, but no coffee comes down... do i need to clean it already, after one grind? any ideas? thanks!
SOURCE: Mazzer Super Jolly Manual
Check out this link for the Super Jolly manual:
http://www.wholelattelove.com/manuals/Mazzer/Super%20Jolly%20Product%20Manual.pdf
Posted on May 21, 2008
EsWorld
  • 1618 Answers
SOURCE: mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Posted on Feb 28, 2009
EsWorld
  • 1618 Answers
SOURCE: Hello. My Mazzer grinder doser Super Jolly (used
It could be that the switch failed, try this to check remove the top part or the grinder burrs and turn it on, if it turns then, grinder was jammed if not switch needs to be replaced.
Posted on Apr 12, 2010
EsWorld
  • 1618 Answers
SOURCE: Ground coffee does not come out
Try this, unplug grinder, vac out all beans, then turn grinder towards fine until you cannot turn the big nut in the center of the burr chamber with your fingers. Now turn adjuster towards coarse until you can barely move the middle nut(you should hear and feel the burs touching) now if you look around the edges of the adjustment ring you will see notches, pick a spot any spot just remember where you started, then turn 14 notches towards coarse, your grind should be almost perfect.
Posted on Jul 07, 2010
EsWorld
  • 1618 Answers
SOURCE: my mazzer coffee grinder brings
Lets do this, remove the bean hopper, and make sure there are no beans in the burr chamber. Then looking down at the collar with the numbers back up screw if there is one on it. Now if memory serves me right clockwise is coarse and counter is fine. Look down in the burr chamber, notice the nut in the middle, turn it with your fingers that will move the bottom burr, if burr turns freely we will move on if not plug in grinder and let it grind out remaining beans. With beans gone unplug grinder, then turn collar towards fine until you cannot go no more, now try turning nut it will be hard if not impossible to move, turn collar towards coarse until you can barely move bottom burr with fingers, you will hear and feel the burrs touching, that will be our bottom setting. Now pick a spot on the grinder you can use the small notch in the middle, count out 16 notches towards coarse and turn collar to that point. Use the notches around the collar not the ones on the top next to the numbers. Your grind should be almost perfect, depending on blend and machine you might have to adjust 1 notch to the left or right after testing.
Posted on Sep 12, 2010
When i turn on the grinder the grinded coffee keeps going on.What should I do?
they usually keep grinding until the compartment with the grinded coffee gets full or until you turn off grinder. should turn off after compartment reaches full state.
Jun 25, 2016 | Mazzer Coffee-grinder SUPER JOLLY Electric
We have a Mazzer Super Jolly grinder and we can not get the dosing lever to move without pulling very hard while holding the machine with the other hand. Please help.
your doser mech is possibly gunked up with old grinds, first off try stripping it and cleaning it out, if that doesnt work you may need a new return spring but i think its far more likely to just need a good clean. this is from the mazzer mini but the doser design is pretty much the same so it should help you with disassembly
http://www.home-barista.com/grinders/mazzer-mini-component-photos-t3577.html
May 09, 2011 | Mazzer Coffee-grinder SUPER JOLLY Electric
I have a mazzer luigi coffee grinder on which set is the best coffee you get
grinding setting is one simple operation but requires a bit patience:
1 turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest ginding) 2 from that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line 3 grind little amount of coffee only to fill one sector of dosser than test it at your machine(if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way. 4 you test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation) 5 after setting measure the grinded coffee that come out from doser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of doser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Nov 14, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
My mazzer coffee grinder brings out medium to almost a whole bean grinds ,,,am trying to get a fine grind(for the espresso) but it's not working ,,, i've tried to move the scale to all the numbers but the...
Aug 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
Jul 03, 2010 | Mazzer Grinder-doser MINI
Apr 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer luigi super jolly
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Feb 19, 2008 | Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer Coffee-grinder SUPER JOLLY Electric Logo
55 people viewed this question
Top Mazzer Coffee Makers & Espresso Machines Experts
Brett Duxbury
Brett Duxbury
Bill Boyd
Mark Cheong
Mark Cheong
Level 1 Expert
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
