Question about Intel Computers & Internet
DURING STARTUP MY COMPUTER IS SHOWING FAILURE OF CMOS BATTERY AND IT GET S/W OFF AUTOMETICALLY. I ALREADY CHANGED THE BATTERY. WHEN I SWITCH ON UPS THE SYSTEM AUTOMETICALLY START BOOTING I NEED NOT TO PRESS POWER SWITCH OR RESET SWITCH.
  • Intel Master
  • 3,799 Answers
When the system is running you need to set the date and time. or set it in the BIOS. Access to the bios varies from board to board but is usually "f2", "del" or sometimes "f10" the relevant button is displayed on the splash screen. The reason it auto starts can be cahnged in the BIOS as well.
Posted on Feb 12, 2012
2 Suggested Answers
  • 5 Answers
SOURCE: motherboard not booting and showing F4 cmos/cnpv
If showing a cmos problem, try pulling out the cmos battery (round circle battery) on the motherboard and wait 30 seconds, then place the battery back in. If you can't get to the bios still, then go out and buy a new cmos battery, or order from a site such as newegg.com
Posted on Mar 01, 2011
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
When connected to power the green light is not showing and the battery light is is always on
This indicates the battery is worn out and will not provide power in the event of a mains power failure.
To test the battery, connect a computer or some other device to the output on the UPS, and connect the UPS to the mains supply. Turn on the mains power to the UPS and power up the computer, then turn off the main power to the UPS and if the computer switch off in a short time.
This proves the battery is old and needs to be replaced.
Mar 19, 2011 | APC APS BackUPS CS 650VA 400W 230V DB9...
Forgotten password
start your computer in safe mode (hit F5 key during startup) go into the Administrator account and hopefully it isn't password protected , go to control panel then to user accounts and select the profile you use and remove the password
Apr 13, 2009 | Compaq UPS R3000 (242705-001) UPS System
Shuts down autometically
Also, have you changed anything lately? and, Did this just start happening out of the blue, or did something happen to cause this, ie... power failure, kicked the plug out, ran the battery completely dead, overheated, etc...?
Aug 26, 2008 | IBM ThinkPad T42 Notebook
Powering up problem on UPS
about your first problem it is not normal.you should check it out with a qualified professional.
after repairing it will work nicely
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
Bootup
Have you tried changing the cmos battery on the motherboard?
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
