Question about Candy Washing Machines
I have a candy gof 662 washing machine, seems to be a problem with the dial, I can set the dial to a short wash, then when i set it to spin at 16,000 it has started to re wash the load
Candy GO F 662
5 Suggested Answers
SOURCE: Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Posted on Nov 11, 2008
  • 103 Answers
SOURCE: CMD 126 candy washing machine struggles to spin even at low load
hi your balt is sliping or your ford geers are ded
Posted on Apr 05, 2009
  • 21 Answers
SOURCE: unit runs good through wash cycle then while in
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Posted on Feb 14, 2010
SOURCE: candy aqua 10t user settings
http://service.candy-domestic.co.uk/manuals/pdfs/AQUA%201000T.pdf
I have found you a user manual, to download and read, this should help you resolve your issue.
Posted on Jun 03, 2010
My candy washing machine isnt spinning on a quix wash
are you trying to spin one item as on these machines you cannot do this under load sensor will be tiggered
try the quick with nothing in ur machine if all goes well then above would apply
Dec 29, 2014 | Candy Washing Machines
I have a Candy GOF 662 and the dial seems to be out by two Programs
There is a plastic lug broken off inside the dial. If you pull the front bit off you will see that the front is held in place by it. You probably need a new dial, but, in the meantime, mark the front bit with a permanent marker with numbers corresponding to each function you need. It may not be the same number of clicks, but it will be the same distance around the dial.
Apr 26, 2014 | Candy Washing Machines
Do you have a user manual for gof 462 2/8
Dear Sir:
go to www. fitness.manualsonline. com or www.retrevo.com
or www. manualsfactory.com
God bless you.
May 13, 2012 | Candy Washing Machines
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
Machine seems to work, but will not empty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Candy DQW150 Front Load Washer / Dryer
Candy aqua 10t user settings
Jun 03, 2010 | Candy AQUA1000T Front Load
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Dec 11, 2006 | Candy AQ130 Front Load Washer
Washing Machines Logo
284 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
