Magic sing microphone 7 pin connector wiring problem
All of the colored wires connected to the seven pin connector disconnected...which color of the wires and which pin should be together..pls help me
surek
  • 10 Answers
SOURCE: magic sing
Dear friend,
The microphone schematics are not found on their website, but I could find their support details at http://www.magicsing.com.ph/support.html
They might be able to address that.
Cheers
Cass
Posted on Apr 22, 2008
SOURCE: Magic Sing EG-18000 Microphone Delay
Your problem is your connection to the TV and maybe your Magic Sing configuration.
Can u specifically describe how you have it connected?
Posted on May 04, 2008
  • 30 Answers
SOURCE: Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Posted on Aug 27, 2008
mighty thor
  • 51 Answers
SOURCE: Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Posted on Nov 24, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
I have connected the Magic Sing to a HD TV and a home theatre system and now get a sound-lag between the voice and the sound on the home theatre. Any ideas?
You need to connect directly the sound wire of your magic sing to your home theather while the video wire of your magic sing directly to your hdtv. If its difficult to do because of distance, buy an rca extension to extend your magic sing wire to make it reach to the other end.
Dec 26, 2009 | Magic Sing Along Consumer Microphone
I would like the color breakdown on the wiring diagram
colors are on the bike side of the connector are spelled out in the shop manual, however they do not include what is used for the headset side of the connector. These are the three pin numbers on the connector that appear to be the ones for the microphone portion. Hope it helps. For the whole setup the passenger uses 5 pins and a tab; while the driver uses all 7 pins plus a tab. So, on a HD three wires will not correctly interface with the system.
pin 4 =BK = MIC Common
pin 2 = passenger gy/bk & Drain = MIC Shield
pin 2 = front y/bk & Drain = MIC Shield
pin 1 = red = MIC
Jul 19, 2009 | 2008 Harley Davidson FLHX Street Glide
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Don't know the conections of blue or red
If we're talking about the microphone cable wiring on a low impedance mic remember this. Cheap mic cables with XLR's on both ends often have no standard color code to follow. True pin 1 is ALWAYS ground (shield wire) but the other two wires could be any color of the rainbow. Look for small numbers beside each pin of the XLR connector and make sure that pin two on one end of your cable, is also pin two on the other end as well....etc. Special note: The XLR connectors set screws have reversed threads and it's the same for the XLR male plug in the bottom of the microphone as well.....Glen
Dec 24, 2008 | Shure Beta 58A Professional Microphone
Song chip not recognized
hi im joe,
i think the problem is the gold colored pins or plate in the song chip is corroded with stain or dirt. try to remove the song chip casing and use an pencil eraser to remove the dirt or stain on the gold colored pins or plate of the chip. please reply if the problem is solved
Nov 06, 2008 | Magic Sing Along Consumer Microphone
Wire diagram
I took care of the problem. The wire colors were by next to each post with the color of the wires on the front panel.
Sep 26, 2008 | Kenmore Refrigerators
Can't power ON...
See if the microphone connector wiggles. It shouldn't move, but if it does, the legs on the connector can snap inside.
Aug 14, 2008 | Magic Sing Along Consumer Microphone
Worn out wires
I found this shop on the net.
http://www.webbyshop.com/shop/pid213/enter-tech-magic-sing-rca-cable.html
Oct 30, 2007 | Magic Sing Along Consumer Microphone
Gemini djm-1 gooseneck microphone repair question
No problem! 2=RED 3=Black 1=White The wire without a color is ground. It can be soldered to pin 1 if necessary. Hope this helps.
Nov 05, 2006 | Gemini Sound Products DJM-1 Microphone
123 people viewed this question
 Grubhead
Grubhead
