Question about Whirlpool Refrigerators
Model #et8chmxkb06 alot of water in the bottom of the refrigerator
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My refrigerator is not keeping
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 31, 2010
Refrigerator leaks alot of water from freezer area
Most of the time you have a clogged/frozen drain. If this is a freezer on top model, you need to remove the back wall or floor and defrost the drain with warm water or hair drier ... I find that warm water and a turkey baster works best.. just keep shooting the water down the drain hole until it takes the water down on its own. If the problem returns sometimes you will need to install a drain heater or conductor kit. If this is a side by side model the repair is about the same ..just remove the freezer back wall and melt the ice and flush the drain.
Mar 08, 2014 | Westinghouse Refrigerators
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Our refrigerator is getting a pool of water underneath the crisper bins. We do not have the ice maker hooked up. Water drips down and freezes into ice on the bottom of the refrigerator inside. I am not...
water is coming from the defrost cycle and is not making it to the drain pan on the bottom. try cleaning the coils and if you can locate the drain that goes to the pan and blow in it this will clear it out. thank you.
Apr 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer door leaking alot of water on floor no ice on door
This really sounds like a plugged drain. When the unit goes into defrost the water should run down the drain into the drain pan...when the drain is plugged it will run over and down to the bottom of the freezer thus leaking out the bottom of the door and onto the floor. You will need to take everything out of the freezer and remove the screws that hold the back panel on break out the ice at the bottom and use hot water to pour down the drain to clear it.....also if you have a small hose to shove down the drain that will help out alot.
Oct 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE side by side model GSS25SGRE is leaking water toward the front of the unit. We have pulled it out to see if it was condensation and that is not the problem. At times there is a lot of water that...
okay, my name is marclavoris, what happens is your refrigerator goes into defrost, the heaters comes on and melts the freon off the coils, the water goes down in the drain, which you will see on the freezer side at the very bottom of freezer, you may need to take off inside back panel to access the hole. it is clogged up with alot of debri, so when it is backed up, it overflows under your bottom tray, it then goes into defrost again and it pushes water on your floor. To solve problem, clear the drain in the freezer
Sep 12, 2009 | Refrigerators
I have a Kenmore freezer on the bottom and wonder where is the drip pan.
it might not have one.alot of the refrigerators use the bottom of the frame around the compreesor area.the heat evaporates the water from the compressor.just follow the drain line in the back and see where the water is dumping into
Jan 02, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
258 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
