Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin cycle suddenly failed to operate
Washing machine agitated, washed the clothes, pumped water outbutfailed to spin. When plugging in the washer and trying to activatethespin cycle, there is a noisy sound like something turning in themotorbut no spin happens.
  • 1,543 Answers
Looks like coolguy008 did a lot of cutting and pasting of canned answers, but he still may have missed a real possible solution. The noise you hear may be just the pump motor running. Most washers will not start to spin if the washer thinks there is still water in the tub. When the tube from the tub to the water level switch gets plugged up with goop, the air does not escape back down when the water gets pumped out and thus the washer thinks there is still water in the tub and will not spin. Take the tube off the tub side and clean it out or cut off an inch and put it back on. You can confirm the diagnosis without doing the cleaning if you open the washer's backsplash and pull the tube off the water level switch (right behind the water level / load size knob) while the machine is in the spin setting. If the tube is plugged, this will cause the washer to start spinning, as the washer now see that there is no water in the tub. Of course you will now have to clean out the tube as for mentioned. Please rate this solution. Thanks, and good luck with your repair.
Posted on Oct 24, 2008
    Genius:
  • 3,422 Answers
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • Ifthe motor is running, your washer probably has a frozen pump pulley ora broken pump belt. To check the pulley, remove the pump from thewasher and try to rotate the pulley manually. If it doesn't turnfreely--if it's frozen or stiff--replace it. If the pump belt is brokenor looks quite worn, replace it--but be sure to check the pump pulleybefore you change the belt.
  • If the motor isn'trunning, the lid switch may be defective. If so, the washing machinecan't spin and may not function at all. The switch is inside thewashing machine main housing near the door frame. Often you have toraise or open the top or front of the washing machine to get to theswitch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • Thelid switch may be defective. If it is, the washing machine doesn'tspin. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
  • The motor coupler may be broken. ManyWhirlpool®-manufactured washers use a small, relatively inexpensivemotor coupling. It's plastic and rubber and is mounted to the shaft ofthe motor on one side, and to the transmission on the other. Over time,the coupler wears out and fails. You may need to replace it.
  • Abelt may be broken. Many washing machines have one or two belts. If abelt is broken or badly worn, you need to replace it with a genuinebelt from the manufacturer. (Some washing machine belts are designedwith special characteristics not found in automotive belts.)
  • Theclutch may be worn. If your washer is a GE, it may use a clutch to comeup to the proper spin speed. As the clutch wears out, it may preventthe unit from spinning well or at all. If the clutch is worn, you needto replace it. For this job, you probably want to hire a qualifiedappliance repair technician.
  • The drive motor may bedefective. Many washer brands use a reversing motor. For agitation themotor runs in one direction, for spinning and draining, the other. It'spossible for a motor to burn out in one direction and continue tooperate in the other. If this happens, you need to replace the entiremotor.
  • The transmission may not be shifting properly.Older washers produced by Whirlpool® have a transmission with anelectro-mechanical shifter. If the shifter becomes even partiallydefective, the unit may drain the water but not spin. This is a complexsystem, if your washer has a shifter problem, you may want to hire aqualified appliance repair technician to repair it.
  • Thespin bearing or basket drive may be worn or seized. These componentsallow the inner tub to spin freely inside the outer tub. When this isthe problem, you usually hear a loud sound during the spin cycle. Calla qualified appliance repair technician.
It spins only with the lid closed Forsafety, washing machines are made so that they spin only with the lidclosed. The lid switch prevents the spinning action when the lid is up.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Whirlpool washer wet after spin cycle
Hello.
1 Measure your drainpipe to make sure it is no taller than 96 inches in height and no shorter than 30 inches; otherwise, it won't pump enough water from the washer, or the water may flow back to the washer.
2 Look at the dial selection to make sure you have selected the proper spin speed for the material you are washing. Choose the highest spin speed for that particular material. If you choose the "no spin" or "low spin" option, your whirlpool washer might not remove all of the water from your clothes.
3 Check if you have chosen the appropriate wash cycle for the type of material you are washing. The whirlpool washing machine drains quite a bit more slowly on the "Delicate" and "Hand Wash" cycles.
4 Check for excessive soap suds accumulating in the washing machine. whirlpool recommends you use only high-efficiency detergent in whirlpool washers. Other detergents can cause excessive soap suds, which could cause the washing machine to operate at a slower spin speed than selected, resulting in sopping wet clothes.
5 Add more clothing items to the washing load. If you wash only one large item, like a coat or blanket, the washer might become unbalanced and react by lowering the spin speed, causing the machine to not drain as it should during the spin cycle.
6 Examine your drain hose for clogs or kinks. Straighten the hose out to allow water to flow through. Eliminate blockage in the drainpipe or utility sink.
Thanks.
Nov 01, 2011 | Washing Machines
Washer will agitate but will not drain or spin in
hello. I can help you. Your washer has two rather complex problems. Here are all of the possible things that could cause the problems you have:;
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
It doesn't spin If your washer won't spin, check these:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jun 07, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
No Spin Cycle
Your machine won't go into spin cycle most probably because it awaits for pump to start extracting water out of the basket. If the "Door Locked" light is on th an it means that either filter, pump or drain hose are clogged (unless pump burned). Turn off machine, unplug the machine, clean the filter, check for foreign objects inside filter and pump housing and finally check/unclog the drain hose.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Old GE Washer WNSR2100T8WW will not pump out water nor spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 12, 2007 | GE WJSR2070B Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
