Question about Compaq Evo D500 PC Desktop
EVO D500 doesn't boot up from my 120gb hard drive
I've tried to upgrade the hard drive in my EVO D500 from 40gb to 120gb. The computer detects it but when I want to boot up from it it gets stocked. Can anybody give me any idea on how to solve this problem?
Thanks in advance
  • gocub Oct 24, 2008
    Yes, I ghosted my 40gb to the 120gb, so i can use my 40gb for storage only.
  • gocub Oct 25, 2008
    I'm sorry I didn't get back to you earlier. I did what you told me, but it didn't work eigther. The model is Comaq EVO D5pM no EVO D500., so if you have any idea please let me know.
    Thanks in advance
  • 128 Answers
Have you installed an Operating Sysem on this hard drive?
Posted on Oct 24, 2008
  • cpenny29 Oct 24, 2008
    ghosted?! guess you've used Norton Ghost! anyway, check for the jumper of the hard disk if it is set to Master. if still it won't work, set it to 'Cable Select'
    if the 'Master' select works set the jumper for the other hard drive to 'slave'
    do the first step without connecting the 2nd hard drive and see if it boots up.
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 09, 2012 | eMachines E442 E442-v133 15.6" Notebook...
My compaq evo D500 sff blicks red light can't start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jun 18, 2012 | Compaq Evo D500 PC Desktop
Can not find operating system in evo n115
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty..Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jun 14, 2012 | Compaq Evo Notebook N115
PXE-61: Media Test failure, check cable
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
How do I install an operating system on my Compaq EVO D500? The hard drive has been wiped clean and there is no operating system on it. I have a windows 98 SE uprade disk.
Hi, you can only use an upgrade disk for win98 if you have win95. If you do not want to purchase an OS, look into linux. I've been very happy with openSUSE and Ubuntu.
May 20, 2011 | Compaq Evo D500 PC Desktop
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Im trying to upgrade my hard drive from a 40g to a 160 but it only shows up as 40gb
You probably used software to "clone" the "old" disk-drive to the "new" disk-drive. So, the "new" drive is an *EXACT* image of the 40GB drive.
Click Start
Point to My Computer
Click with the SECOND (usually the RIGHT) mouse-button.
Click Manage
Double-click Storage
Double-click Disk Management (local)
You'll see that the "last" 120GB on the new disk are "unallocated".
Use that "disk-cloning" software to "resize" the 40GB partition on the new disk-drive, to integrate that "unallocated" space into the current partition.
Or, right-mouse click on that "unallocated" space, and create a partition within that space, and to "format" that space, and to assign a drive-letter (E: ? F: ?) to that 120GB of disk-space.
Nov 11, 2009 | Dell Dimension 3000® Pentium® 4...
Openign the case of evo d500
I just worked on one. You have to make sure the buttons on each side are fully pushed in, then grab onto it and pull forwards while kind of shaking it. It came off straight upwards. Hope it works for you. Good luck. I don't think it had the option to add another drive but I wasn't looking so I could be mistaken.
Mar 08, 2009 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
My son changed towers and upgraded to another power supply
How long have you waited for it to boot up? Sometimes I have seen it sit on the logo for like 10 minutes thinking about the boot configuration. Also you might change out your hard drives and cd's and DVD's and check your jumper settings on all of them to see if any conflict with each other.
Jul 29, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Compaq Evo D500 PC Desktop Logo
151 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
