Question about Nikon COOLPIX S570 Digital Camera
Red flashing clock icon - won't switch off - what does it mean?
Flashing green light
hello,are you sure that you have not left your camera flash on,and virtually killed off the battery?as the zig zag icon usually refers to mostly flash related aspects of most modern cameras,all cameras need a certain base level battery power,before they will switch on for use,but may well display all manner of icon's and oddity's when the power is all consumed.hope that helps, cheers.
Jun 02, 2013 | Nikon COOLPIX P510 16.1 MP CMOS Digital...
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
It won't turn on, the red light flashes
That means that its no good and needs to be replaced
Aug 02, 2012 | Emerson LC320EM8 32 in. LCD TV
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
Mar 19, 2012 | Televison & Video
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | Computers & Internet
I hve a nikon coolpix 10 MP but the image quality is poor....i have tried resetting all the camera settings to default and dont know what else to do....also, it keeps showing a red colored icon (it...
The red clock indicates that the date and time need to be set.
As for the "poor" quality, there are many possibilities. If the colors are wrong, the most likely culprit is an improper white balance setting. If the pictures are blurry, that could be caused by subject motion, camera motion, improper focus, or a combination of the three. If pictures taken with the flash are too light or too dark, that could be because the subject is outside of the flash's range. Without knowing what you mean by "poor" I can't give you anything more than some ideas.
Dec 27, 2011 | Nikon COOLPIX S220 Digital Camera
Flash not working
First, be aware that the flash only works in still mode, not in video mode.
Second, check the macro/far switch on the left end of the camera. The flash won't fire if this switch is in the macro position (flower icon).
Feb 13, 2010 | Vivitar ViviCam 8025 Digital Camera
I am getting a flashing red icon that looks like a clock and I have no idea what it means!
The date isn't set. Go into the Setup menu, select Date, and set the date and time for your location.
Feb 03, 2010 | Nikon COOLPIX L18 Digital Camera
HOW TO ACTIVATE THE FLASH
Dec 25, 2009 | Vivitar ViviCam 8025 Digital Camera
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Nikon COOLPIX S570 Digital Camera Logo
94 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
