Question about Miele W4840 Front Load Washer
Waterproof system activated w3740
Waterproof system activate on miele w3740
5 Suggested Answers
SOURCE: Miele WT2670 message on screen
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Posted on Aug 01, 2009
  • 177 Answers
SOURCE: my miele touchtronic w 3039
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Posted on Mar 02, 2010
richroth
  • 9472 Answers
SOURCE: need advice how to de-activate
Posted on Jan 16, 2011
tunde007
  • 2382 Answers
SOURCE: waterproof system activated. close stopcock. The
Hi, it's caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie. Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work. You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics
Posted on Mar 05, 2011
I have a Miele W 2389. Message saying waterproof system has activated. Turn off stop ****. What does it mean?
Hi Dear. Seems like your machine had internal leak. Float switch has been activated. That triggers error message on the display. What you can do is: Tilt the machine 45 degree (Back or forward which ever easy for you) wait for leaked water come out underneath the machine. If water comes out of machine, it's a indication of one of the plastic component failed(it could be drain hose- tub to pin trap hose- may be inlet valve etc....) If there is no water coming out of machine, float switch may be malfunctioning. In that cases you need to contact Miele center to get help.Thanks.
Apr 17, 2016 | Miele Washing Machines
My miele wt 2679 wpm has appeared waterproof system activated.how to deactivate it.
Make sure the door is closed, then pull the plug out of the wall or turn off the 15 A breaker at the panel for 30 secondsd, then plug back in, or turn the breaker back on.
This is like a hard boot for a computer or to clear a problem which is locked like this.
That is the first easier fix to try first.
I hope this may help!
William R
Mar 27, 2015 | Miele Washing Machines
When attempting to start dishwasher load the signal F 70 come up and it wont work. Purchased 2nd Jan 2008.
F70, waterproof system activated. this means you have water in the bottom pan of the dishwasher. your miele shuts itself off and runs the drain pump continuously any time water leaking is detected. you can pull out the black plastic toe kick under the door. there is a cover panel in the center held on with two t20 screws. you can dry up the water and try to run a cycle. if it works ok, cut back on your detergent by 1/2. if it leaks again, you should probably request service from miele. if you want to try to repair it yourself, let me know and I will help you troubleshoot it further.
Nov 17, 2010 | Miele Dishwashers
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Feb 16, 2010 | Miele W2203 Front Load Washer
Water protection system activate - how can i deactivate?
how do you fix machine when waterproof fault comes up even after draining machine?
thanks Linda
Aug 23, 2009 | Miele W4840 Front Load Washer
Miele WT2670 message on screen "waterproof system activated". How do I reset?
Jul 17, 2009 | Miele Washing Machines
Wps code
Simply disconnect it. Water completes the circuit - so you want to make sure it is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Washing Machines
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele transit rods stuck
My husband was able to pull it out .
Feb 27, 2008 | Miele Washing Machines
Miele W4840 Front Load Washer Logo
140 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
