Question about Pentair Dryers
No power to pump
I have an onga enviromaster pump. i lost power to my house briefly which tripped a circuit breaker. now there is no indication of power to my pump, but power is present at the switch
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: Heat pump trips circuit breaker
i want to know the size of breaker to use.we are using a 30,30,30,30but it is kicking off.would a 40,40,40,40or higher be better if they sell them.
Posted on Nov 22, 2008
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
bigg t
  • 640 Answers
SOURCE: Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Posted on Apr 11, 2009
SOURCE: Carrier air conditioner
i have nothing on my thermostat. I was going to install a programable thermostat so I disconnect my old one. When I couldn't use the new one I reinstalled the old one and now it's like there is no power to it. Checked circuit breakers and found none tripped and tried thermostat in upstairs since I have two thermostats and it works fine there What next???
Posted on Jul 22, 2009
Does the onga spa master 4352 have a fuse or overload switch?
try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
Aug 19, 2014 | Pool & Spa
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
Manufactured home electrical problem
Look in your Circuit Breaker Panel for a circuit breaker that is tripped. A tripped breaker is indicated by the handle being in the middle between the ON and OFF positions. Turn it OFF then to the ON position.
It's also possible that you have "lost a leg". There are 2 hot wires and a neutral that come into the main panel. One of those hot wires have become "lost". While it is not difficult to determine which leg is lost and where, you should call a qualified electrician because of the hazards involved. It could be anything from the main breaker itself, the meter, the connection at the weather head, or even on the Power Company side.
Dec 13, 2011 | Gb Electrical 100 Amp GE Load Center
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    Trips on power up
    It has a short circuit on the final steps of the outputs, maybe the common called "final transistors or power amplification IC (integrated Circuits)"are blown. You don't have the ability to resolve this problem, so take the unit to a facility authorized repair.
    Dec 29, 2009 | Behringer EUROPOWER EP2500 Amplifier
    Bathtub pump totally dead, pump ran dry for 10 sec, is there circuit breakers on pump motors, switch or is it the motor shot. any way to test motor with removing it?
    Normally pump motors are connected on a separate
    circuit with its own circuit breaker. At your house there is always a electrical control panel housing several circuit breakers for lights, power outlets, range, aircon, motors, etc...Find a tripped off breaker and reset it. To reset the circuit breaker is to switch it to off position and back to on position. Better still you may reset all the circuit breakers except the main
    circuit breaker (biggest amp rating).
    After resetting the circuit breakers, try to switch your
    bathtub pump on, (to test it, if it is still okey). Other-
    wise, your motor is damaged and you got to have the
    motor rewinded, to be operational.
    Dec 09, 2009 | Plumbing
    Iron tripping my electric
    Check the power label on the unit to see if it is indicating a higher requirement than what your circuit breakers and house wiring is rated for. I have seen some professional equipment indicating 20 amps, and the house power was rated to 15 amps maximum. In this case an electrical contractor had to be called in to replace the wiring and and circuit breaker to meet proper specs. This is expensive!
    If the unit is rated under the house power available and the breaker is tripping, then there is obviously a defect in the device and service is required. I have seen heating elements go partialy shorted, or there were thrmostat faults and the device was overheating.
    Jerry G.
    Apr 26, 2009 | Russell Hobbs RC100A 10-Cup Rice Cooker
    Cant get motor to work
    If it's a 120 volt circuit and timer, it sounds like you lost your neutral connection. If it's a 240 volt circuit/timer. it sounds like you lost one leg. Measure the incoming circuit voltage to the timer that's not working_wire_ to _wire_.
    Also, go to your main circuit breaker panel and turn the breaker for that circuit OFF then back ON. The pump may have just tripped the breaker. Sometimes breakers can look look they are ok, but they have actually tripped. It's possible that the pump is bad and it's tripping the breaker. Are you able use the manual switch to get the pump to work? ( the one that stopped running last week.)
    Feb 11, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
    I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
    Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
    Dryers Logo
    20 people viewed this question
    Top Pentair Dryers Experts
    Dan Webster
    Dan Webster
    Are you a Pentair Dryer Expert? Answer questions, earn points and help others
