Question about Teac Computers & Internet
TEAC N533 drive set up OK but doesn't read diskettes
I bought a TEAC N533 drive and it set up fine via the USB. However, it does not read the diskettes I bought it to read! Says they need formatting. They read OK on old pc. What can I do?
3 Suggested Answers
  • 7 Answers
SOURCE: Teac usb portable diskette/got cd but useing windows vista
Try this solution.
http://www.fixya.com/support/t357073-need_vista_driver_fd_05pub_teac_usb
Posted on Dec 01, 2008
bronk50
  • 27725 Answers
SOURCE: I have a Teac USB
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 28, 2011
Teac n533 12v LED/TCD DIGITALT/V
First; try blowing into the DVD reader, sometimes it is just a hair. also try a DVD cleaner disc. Check if the drive spins up correctly, and "listen". If it's spnning but having trouble reading you will hear a whizzing sound as it tries different speeds.
May 06, 2014 | Teac Audio Players & Recorders
Usb portable diskette drive driver
Usually their is a hole in the front to insert a straightened paper clip. Push the clip deep, it will connect , and the door will open.
Dec 05, 2013 | Teac Computers & Internet
Does't work anymore
I would call the phone company back, if what you say was caused by them..
May 24, 2013 | IBM USB Portable Diskette Drive (05K9276)...
What connections are required to set hard drive function (Master, Slave, etc) in this case for use on a USB extender
Doesn't matter where the pins are if the drive is being connected via usb because it will act as a internal drive. If anything, just set the jumper to Master.
Nov 08, 2012 | Computers & Internet
Free download of Drive Portable Diskette Drive-N533 for Window 7
Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8. Try it!
May 05, 2012 | IBM USB Portable Diskette Drive (05K9276)...
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
I have a Teac USB portable diskette drive, N533. Until recently, it has worked okay. However, it has started not opening any diskette I put in and instead a message appears that the disk needs to be...
hope this helps
Apr 28, 2011 | Teac IBM USB Portable Diskette Floppy...
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Try this solution.
Nov 25, 2008 | Teac FD-05PUB External Floppy Drive
Need vista driver for FD-05PUB teac usb floppy drive
You should have (if bought new) had a mini disc in with the drive. If not try the manufacturers site and download it. It's also possible by doing the add/remove hardware and pointing towards Microsoft for the driver it will install for you. Hope this helps...Tango.
Jan 17, 2008 | Teac FD-05PUB External Floppy Drive
Computers & Internet Logo
168 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
