Question about Panasonic Office Equipment & Supplies
PANASONIC FAX MODEL UF-5100 - ERROR CODE 634 - Panasonic Office Equipment & Supplies
MitchSchaft
  • 25 Answers
SOURCE: Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
Note:
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Posted on Jan 25, 2008
leroyal
  • 2120 Answers
SOURCE: PANAFAX UF-6000
No dial tone....check the phone line with a regular phone.
Posted on Aug 31, 2008
leroyal
  • 2120 Answers
SOURCE: Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Posted on Nov 21, 2008
  • 5 Answers
SOURCE: fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Posted on Apr 09, 2009
  • 272 Answers
SOURCE: MACHINE GIVE ERROR CODE 5100?
I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100. Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on May 30, 2009
Info code 634
Communication error! press monitor button should hear dial tone if yes (good) if not check phone line make sure phone line in correct jack marked (line)make sure issue is not happening on 1 certain transmission(number)!problem if multiple numbers.
Nov 24, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What is error code 634
Error Code 634 indicates a call that was placed did not go through:
"Redial was not successful due to no response from
the called station or wrong number dialled.
Note: If busy tone was not detected, the machine will
only redial once
Sep 03, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Fax can not be send and received
press the monitor key...you should hear a dial-tone...if not try below.
Check the phone line with a regular phone plugged into the wall jack.
Mar 11, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Getting weird comm.
error code 634 means that your machine tried a phone number and reached its redial limit. does this happen to every call or just one number.
if its all the time it could be you phone line is not connected or you need to do an all job clear
Nov 26, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Nov 21, 2008 | Office Equipment & Supplies
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
322 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
