Question about Nintendo Wii Console
Wii fit I get thru the whole creating my avatar but then when I get to the body test i keep getting the message "please step off of me" when I am not even on the board. What is going on. I have reset, changed batteries, re-sync'd, I have turned it off for 20 mins, i still cant get past the same message.
  • Anonymous Dec 30, 2008
    I have the same problem - did all the troubleshooting - no luck
    President:
  • 4,402 Answers
You have a bad pad, return
Posted on Oct 24, 2008
My wii fit keeps say pleasae step off me and press a when i go to do the body test
Replace your Wii Fit Plus board and/or DVD disk. I had the same problem. The seller has gave me a new Wii Fit Plus set (instead of the 1st one), and everything was OK. I don't know if the problem was in the board or in the DVD disk.
Aug 14, 2010 | Video Game Consoles & Games
Disc doesn't work when I change from body test to training on Wii
Wii Fit? The problem can be that your Wii is modded (IF ITS MODDED), or that the disc contains scratches.
Nov 21, 2009 | Nintendo Wii Console
I keep getting the message to "step off and press A" for the body test.
You need to step off the pad, wait until it tells you to step on. Then you push A to conduct the body test. If your pad is turned off push the button on the front of the wii fit pad then repeat the first steps i described.
Aug 03, 2009 | Nintendo Wii Fit for Wii
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
Jan 17, 2009 | Nintendo Wii Fit for Wii
"Step Off Me and Press A" message while not on wii board
When you get this message, lift the board off the ground, press A, and wait until you get to the confirmation screen before placing the board back on the ground. You may have to try a few times to get the timing right. I have no idea why it thinks someone is on the board, but this workaround has solved the problem for us. Good luck.
Jan 04, 2009 | Nintendo Wii Fit for Wii
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Dec 29, 2008 | Nintendo Wii Fit for Wii
'step off me and press A' message when not on - cant get further
HI HAVE THE SAME PROBLEM ( STEP OFF ME AND PRESS A MESSAGE )
ANY BODY WITH THE ANSWER TO THIS PROBLEM !!!!
ONLY GOT THE WII FIT FOR CHRISTMAS 1 WEEK OLD !!
Dec 28, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
