Question about Canon PIXMA iP90 InkJet Printer
Opening cowl How do I open the printer so I can get to the USB port to see if it is damaged?
Just to add to the cover removal. You will need to ease a flat screwdriver in the front to release the 2 catches. It does help if you have eased the rear and sides slightly first. The position of the lugs are 1 cm in from each side going from the middle, or where the plastic top seats.
Also there is another catch on the front left that needs to be released otherwise you will damage the bluetooth holder.
Posted on Feb 12, 2009
  • 34 Answers
You need to remove all the screws on the front and rear of printer then, insert small screw driver into slots on the back and sides, then just lift covers off. There is not way of telling if the usb port is damaged, you just replace it. However once you open the printer you must go into the service mode after it's reassembled in order for it to power up properly, otherwise it will be dead in the water.
Posted on Nov 11, 2008
Printer stays offline
open printer and fax
right click on printer
select properties
select port atb
chaining port to usb vartuala port
try with port 2 and all
Mar 14, 2014 | Star 37999190 -Micronics Sp712mc Dot...
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
Existing TALLY file damaged D:/Tally/0001/Tr01339.500 Size:116992 Position:116224 Chars:128(done 128)
Please post your question in the form of a question including all necessary details **** as operating system, what you are doing when the error occurs, what you are trying to print, from which application, etc etc etc.
Aug 15, 2011 | Tally T2250 Matrix Printer
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
How do I add a printer to my laptop
At this time, a full feature Windows 7 driver solution is not available for your product.Follow these steps to install and configure the driver that is compatible with the product.
Follow these steps to install the compatible driver in Windows 7.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select the Deskjet 660c and then click Next.
  9. In the message window, click Finished .
  11. close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  15. Click OK .And print a Test Page.
Regards,
Riztech
Jun 01, 2010 | HP DeskJet 656c InkJet Printer
I need to connect my hp 1115 printer to my windows 7 computer and I don't have disc to install it. Please help!
We can use generic drive of deskjet 550c to install this printer. Just follow the below simple steps to fix the problem.
  8. Under Printers,select HP deskjet 550c and then click Next.
  15. Click OK.
Thanks and Regards,
Rizwan
Feb 01, 2010 | HP PhotoSmart 1115 InkJet Printer
Cant install my hp deskjet 3325 printer to the windows 7
Follow the below steps to install your printer in Windows 7.
  8. Under Printers , select Deskjet 3600 and then click Next .
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
My USB ports are not working. I Updated BIOS and each USB driver and HUB individually and still nothing is working in the ports.
Are the usb ports enabled in bios? and set to hi-speed?
I have had this problem where the port was damaged and overcame it by buying a usb port pcmcia card. To confirm it's physical damage you'll have to open the laptop up
Jan 11, 2010 | Acer Computers & Internet
My printer have a problems in lan and usb card has damage
hi,
if the lan port is damage and the usb port is damaged, there no way to use it to connect unless the lan port is on a slide in card and the same for the usb port,
You may be able to buy a card with will replace the damaged one, I have seen similar items on ebay.
Regards
GeWiz.
Dec 21, 2009 | HP LaserJet P2015dn Printer
MFC-210C
Yes, this is a USB printer. The connection will be very small, either a slot, or a square hole with two corners cut off. The cable will connect to a USB port on your computer (the aforementioned slot).
Aug 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
43 people viewed this question
old marine
old marine
Corne Viljoen
