Question about Kitchen Ranges
Chef royal instructions
Want to know how to light grill and oven. No instructions and am a bit wary when it comes to gas!
  • 833 Answers
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
Smarticus26
  • 30 Answers
SOURCE: Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Posted on Jan 15, 2009
Maytag317
  • 1136 Answers
SOURCE: Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Posted on Jul 15, 2009
heatman101
  • 43501 Answers
SOURCE: I have Magic Chef -
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Jan 09, 2011
SOURCE: main oven dont light there is no gas coming through
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Posted on Nov 30, 2011
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
I have Magic Chef gas oven. Model CPR1100ADW. The pilot light don't light up nor does it come on. I don't smell gas coming from it. I can't figure what it is. Can you help me.
The oven probably has an igniter to light the pilot, and when not in use, shuts the gas off. Unplug the stove to replace the igniter. Enter your stove info and "how to replace oven igniter" on you tube for videos and detailed instructions.
Dec 14, 2017 | Magic Chef Kitchen Ranges
My elderly neighbour has the above oven and she cannot light the oven when i turn it to the required temp no no gas comes out she has a Hygena Classic built in oven
http://argos.scene7.com/is/content/Argos/4894865_R_D001pdf this is all I find were I you I would suggest calling out a repairman. these units being GAS and having the potential to explode makes me wary of DIY fixes
Mar 06, 2016 | Ovens
Chef Regency Gas Wall Oven - oven fan working,light working , grill working as well but the main oven not responding when turning dial. The Piezo ignition is intermittent and no gas sound coming out.
The Piezo control board opens the gas valve while it makes a spark. Once the flame is lit the milivolt flame sensor holds it open from there on. Replace the piezo control board to fix.
Jan 16, 2016 | Kitchen Ranges
How do you light the gas grill
I assume outdoor gas grill? If so, turn on gas at tank. There should be a knob that has a lightening bolt or something similar representing ignition. Turn the knob to that diagram and click the igniter till it lights. If you don't have igniter use a long grill lighter. Once that is lit you can turn other knobs that control other rows of gas if so equiped.
May 17, 2014 | Magic Chef Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Kitchen Ranges Logo
364 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
