Question about Vivitar ViviCam 7024 Digital Camera
I have a Vivitar Digital lens 17.45mm F30 Camera, And I don't know how to turn my Flash on .
SOURCE: vivitar vivicam 5385 digital camera
wont power on even with new batteries please email m e with suggestions www.aol.com
Posted on Oct 17, 2008
hichama9
  • 65 Answers
SOURCE: Camera lens stuck!
Hello Friend,
First i would let you know that the Brand Vivitar is one of low quality cameras, it's sad but it's true.
Now regarding the issue that you have with the lens, you probably drop it because this the only way to have the lens stuck. but anyway, to repair it it will cost you more than a new one. and again i suggest to buy a branded camera like Canon,Sony,Nikon,Panasonic ... these are top quality cameras and you will not have any problem for life except if you drop it ;)
Best Regards,
Posted on Oct 29, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: Lens cover does not open and camera shuts off it
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Posted on Jun 09, 2010
6ylucy
  • 742 Answers
SOURCE: NEED DRIVERS FOR CAMERA Vivitar ViviCam 20 Digit...
http://manualfox.com/driver.htm
Posted on Jun 28, 2010
  • 102366 Answers
SOURCE: Help me turn on the flash on my vivitar vivicam
Press the Flash/Up button repeatedly to cycle through the different flash modes. Your choices are Auto (lightning bolt and letter "A"), Force Flash (lightning bolt), Red eye reduction (eyeball), and No Flash (lightning bolt in circle with slash through it).
Posted on Jul 06, 2010
How to use a vivitar 251 flash
You may download a copy of the manual here. Don't use this flash on a digital camera without isolating it, or it's high trigger voltage is likely to fry your camera.
Sep 06, 2012 | Vivitar Cameras
My nikon D90 felldown from my hand and now the flsh not working ; i mean it pup up but no liting
Assuming you don't have the flash turned off, the most likely scenario is that the drop broke something. It could be a loose or broken wire, or a damaged flash tube. Without an actual examination it's impossible to diagnose the exact problem.
If you know how to repair cameras, you can order a replacement flash head here. Otherwise, take the camera in to an authorized Nikon shop and have them take a look at it.
Yes, I know either option will cost money. But if the flash is broken, it's broken.
Dec 15, 2011 | Nikon D90 Digital Camera with 18-200mm...
Turn it on,don't know if it even works.
Hi There
I assume you found this camera and don't have any information about it.
Here is a link to download the manual.
http://www.retrevo.com/support/Vivitar-3710-Digital-Cameras-manual/id/200ag804/t/2/
If you don't have a cord to connect it to your computer, you can purchase one:
http://www.amazon.com/Vivitar-ViviCam-3710-USB-Cable/dp/B003HMVENA
Hope this helps!
Jul 26, 2011 | Vivitar ViviCam 3710 Digital Camera
I don't know how to turn off the flash
Check the manual, it might be in the manual setting or a physical button depending on the camera model. Thumb me up if I helped. :)
Jul 02, 2011 | Vivitar Cameras
Unable to get Vivitar 2800 on Canon XSI to work.
DANGER! Don't try it again!
That flash is an old fashioned thyrister flash intended for 35mm film cameras ONLY. The voltage which it passes through the foot contacts can fry digital camera circuitry.
It will not work with your camera, you must get a modern unit suited to digital cameras instead. If you're lucky, then your camera has been unharmed, but if not then you are looking at expensive and possibly uneconomical repairs which will not be covered by the warranty.
The 2800 is a great general purpose flash, but it's design pre-dated the widespread use of digital SLR's. Vivitar did release a digital-friendly version called the 2800D. You can use the 2800D on 35mm film cameras as well, but must not use the original 2800 on digital models.
Hopefully your camera is OK and you'll keep your flash well away from it..
Jun 21, 2011 | Cameras
Flash just doesn't work on Kodak Easyshare V1253. whether on automatic flash or flash set to on. Used to have problems with the lens not fully closing, don't know if that helps. All in all, i have...
When you were having that lens problem, did you perchance open the camera case to repair it? If so, please see this link, and afterwards verify that all outer case screws are present and firmly seated (but don't strip them).
May 30, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a vivitar vivicam t027 and there is a slidding button on the side with a flower and I don't know how to describe it maybe a triangle. What does that switch do?
That's the macro switch. In the flower position the camera only focus on subjects close to the lens. This lets you take pictures of flowers and insects, for example. The other symbol is a mountain and in this position the camera focus on objects farther away. You want to use this setting for most subjects, like people and scenery.
You cannot use the flash in macro mode. It's all described on page 12 of the manual. If you need a manual, you can download one from the manufacturer's web site at
http://www.vivitar.com/files_products/410/ViviCam_T027_Camera_Manual.pdf
May 12, 2011 | Vivitar ViviCam X029 Digital Camera
I received the vivitar dvr 850hd with the 2.4" screen. i can't get the flash or strobe light to work to take pictures or movies when it is dark. is there something special that i need to do to get it...
When in the 'Camera' setting, push the left arrow on the camera to 'Auto' or 'On'. the flash should flash if it is dark enough. also, I don't think you can use the flash when making movies.
Jan 01, 2011 | Vivitar Cameras
How do i turn on the flash? vivitar vivicam 5022
Make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Set this switch to the mountain position.
Also bear in mind that the flash is for still photos only, not for videos.
May 15, 2010 | Vivitar ViviCam 5022 Digital Camera
How do i turn the flash permanetly on?
You don't. The flash is for still pictures only, not for videos.
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Vivitar ViviCam 7024 Digital Camera Logo
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
