Question about Saws
My table saw will turn on, but sounds very loud
I used my table saw to rip a few pieces of wood a few days ago, normal work, nothing fancy. Then today I went to use it and when I turned it on it sounds super loud. What could the problem be? The blade looks fine and turns, it just sounds louder than normal.
  • awanabug May 11, 2010
    8" B&D (yard sale) table saw will not run. Checked capacitor with ohmmeter for short, and immediately pegged meter, then slowly increased ohms leading me to believe it is ok. Checked motor ohms seems to be about 275. Checked breaker, seems to be about zero ohms. Any help appreciated.
  • 99 Answers
Possibly bearing wear, or the blade rubbing against the guard/housing. Unplug the saw and spin the blade slowly by hand, if it feels notchy then I would suggest bearing wear. if it only seems to feel notchy in places then it could also be damaged gears.
Posted on Nov 01, 2008
Power outage now tv doesnt work
It should be under warranty. do not panic. Call the manufacturer as soon as possible.
Jun 08, 2017 | LG Televison & Video
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
Can a jig saw rip fence (Skil rip fence model No. 94500), with adjustment on the shaft from zero to five inches, be used to make a circular cut with a 8 inch radius (i.e., a 16 inch diameter cutout)?
no, will never happen. Make yourself a jig, 1/4" plywood set on your table top woth a small brad set 4" from blade. make a tiny hole in board to be cut into circle, spin the board on the brad, and look a wagon wheel.
Mar 11, 2011 | Skil 94500 Jig Saw Rip Fence
Saw worked fine until today. Kicks breaker withing seconds of starting. both 15 and 20 gfci's kicking within seconds.
What I would check for and follow closely, is UNPLUG tool turn blade by hand to make sure it turns freely, there could be a piece of offcut wood jamming the blade. then turn it on its back or however you can to see about cleaning with compressed air, check the cord condition for breaks if all the above checks out and sounds like you have tried different power sources you have an electrical short and troubleshooting this is involved.
Oct 03, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Motor not working on Delta table saw: I just got a used Delta table saw for free, the previous owner said the motor wasn't working. I wonder if it could just be a switch... how could I check that? I also...
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Apr 16, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Re furbish old Craftsman 10'' table saw
It all depends on how much patience you have. It will cut ok, if you feed slowly and use a rip blade to rip with instead of a combination blade. (Buy one with only 36 teeth or 40 teeth). A sharp blade is always a lot easier and safer to use than that old rusty thing that is trying to grind its way through a piece of 2X. Another tip you might try is to put a coat of paste wax on the blade before you start. It will help if there's a lot of pitch building up as you cut.
Otherwise, more hp will be less likely to bog down and overheat, and will allow you to push through denser and harder woods without the danger of overpowering the motor. But even then, a sharp rip blade is a wonder and a joy to use!
Mar 22, 2009 | Craftsman Saws
Delta 10
Replace the blade. It is very dull. Cherry is very hard wood and should be only cut with a very sharp blade.
Nov 13, 2008 | Saws
Delta table saw
The reset button is normally a thermal overload, using a bio-metallic strip to break the circuit. If it is old or has popped a few times it might have 'weakened' abit. Try replacing the thermal/reset button. If it still happens then something might be overheating and causing the problem.
Oct 12, 2008 | Saws
Saws Logo
267 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
