Question about HP Computers & Internet
The sound from my computer sounds as if it is coming through a long echoing tunnel.....how can i fix it?
  • 849 Answers
Go to the media player equalizer and turn off the equalizer...
Posted on Oct 24, 2008
How to eliminate callers getting a feedback echo through my stock bluetooth car stereo?
this happened to me in my truck (sounds as if your talking in a tunnel) what it turned out to be was i did not set up my phone on bluetooth properly (mute interal microphone on bluetooth) but i first noticed a sort of fix for this as i put my phone inside my lunchbox oneday and the echo went away on next call , but after looking into it i saw the mute function on phone bluetooth set-up
May 13, 2014 | 2009 Acura TSX Tech
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
My ipod touch 2nd generation suddenly developed an echo or tunnel while playing. the words are clear but prefer the previous normal sound.
Find if there is reverb. Not sure where you are putting the IPOD into the unit. Turn off the effects for that channel. There is usually a control for each channel that controls the amount of the channel sent to effects in addition to the normal mix gain. It sounds like yours got turned up for the IPOD channel.
May 03, 2011 | Pyle pro Pwma930i Vhf Wireless Portable PA...
Podcasts on my ipod touch have echo
Then, while I was staring sadly at my ipod, wondering why my audiobook sounded like it was playing in a tunnel, I saw a little "1/2x" next to the "30sec-rewind" button on the play screen. I hit it, so it changed to "1x" and miracle of miracles, the echo went away. Apparently there's a slow down and speed up button right there, and slowing something down where it can't, makes it echo. I'd never noticed it before, and I must have hit it accidently.
Feb 18, 2010 | Apple iPod touch
My sound has an echo :(
go in the control panel/ hardware and sounds/ sound then change your setting and configuration and properties under your sound driver.
Nov 24, 2009 | AOpen Computers & Internet
The sound coming from my speakers sounds tinny or like they are in a tunnel.
are you playing music with media player if you are right click media player toolbar go to view then enhancements then graphic equaliser and change sound effects there click on the defalt then a window will open .
May 07, 2009 | Logitech Audio Players & Recorders
Speakers not working right
i know what your problem is...you have the realteck device right??there's some options in the device you can change and everything works
Nov 25, 2008 | Dell A215 Computer Speakers
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Help with Sound
I cannot say directly for your particular model. I will give you a generic answer that can apply to most any computer.
If you hear an echo, look carefuly thorugh the setup for the sound card. Look for anything to do with special effects.
Look for the options or properties that have to do with the sound card that is in the computer. Many of them have special effects capability.
Jerry G.
Apr 19, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
